The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Indianapolis
Fabrications
Talk to Randy Domeck
See what they
can do
for you
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
10 registered members (highland, ApacheFiend, Jimmie D, Fitzy440, 69Cuda, 2 invisible), 406 guests, and 3 spiders.
Forums47
Topics111,105
Posts874,737
Members40,723
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 2 of 3 1 2 3
Re: Ring & pinion gears 49 3600 [Re: imstilllarry] #1240623
Wed Oct 25 2017 11:30 AM
Grigg  Offline
Lexington, VA
He did not, and explained in another thread the vendor was confused, does not have new gears for the old Eaton axle.
https://www.stovebolt.com/ubbthread...ne-ton-rear-end-upgrade.html#Post1239041
1952 Chevrolet 3800 pickup
---All pictures---
Re: Ring & pinion gears 49 3600 [Re: SWEET] #1243328
Tue Nov 14 2017 11:08 PM
Don huffer  Offline
Cape Coral Florida
Can’t find them. Lots of guys looking for them.
Don
Can’t begin to tell you how much I hate the name Stovebolt.
Re: Ring & pinion gears 49 3600 [Re: imstilllarry] #1243340
Wed Nov 15 2017 12:53 AM
SavannahDog  Offline
Georgia's Fresh Water Coast
Why don't we as a group of 3600 and 1 tons find someone to make these. I'm talking about a ring and pinion which makes the whole process why harder. Than pulling a entire pumpkin and swapping it. Isn't there someone in America that has a casting/maching shop.
I have a pumpkin with the correct 4.11 gears. I'm busy with other things Brakes, Master Cylinder, and Seat foam. Mine could be used as a pattern for the first stage of Casting. What ever, I need them back.
How many are needed 200 or more
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
Re: Ring & pinion gears 49 3600 [Re: imstilllarry] #1243344
Wed Nov 15 2017 01:30 AM
Achipmunk  Offline
Boltergeist
Boiling Springs, S. C. 29316
Back a few years ago I went to our local, and reputable, gear maker Griffin Gear.
http://www.griffingear.com/
They, or the "boss" I talked to, gave me about 5 minutes or less and flat told me they did not do "automotive" gears. I believe they once did but evidently not enough interest for their cost??? Just saying.......!
Pictures in my Photobucket
52 Chevy Panel
Re: Ring & pinion gears 49 3600 [Re: imstilllarry] #1243351
Wed Nov 15 2017 02:32 AM
Don huffer  Offline
Cape Coral Florida
What is another option besides the pumpkin swap? Is there another rear end that will match in width?
Don
Re: Ring & pinion gears 49 3600 [Re: imstilllarry] #1243371
Wed Nov 15 2017 05:15 AM
Hotrod Lincoln  Offline
Boltergeist
Dellrose, TN
There are at least half a dozen full floating rear axles that are very close to the right width, with the exact same 8 bolt lug pattern. Dana type 60 and GM corporate 14 bolt are the most common - - - -in Ford, Dodge, GMC, International, and a few other brands of trucks. There's absolutely no reason other than bullheaded stubbornness to stick with the Eaton 3/4-1 ton housing. I've got a mid-1970's Dana 60 from a GMC with a 3.73 gear ratio and a Positraction center section under my 59 Burb right now.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Ring & pinion gears 49 3600 [Re: imstilllarry] #1243378
Wed Nov 15 2017 12:19 PM
Grigg  Offline
Lexington, VA
The GM 14 bolt from a “cab and chassis” truck is best axle swap in my opinion.
Width is perfect, lots of gear ratios available, some even faster than practical.
Brakes are large, available, and economical.
Spring perches do need moving. Better to replace with aftermarket bent steel ones that match spring width.
Brakes as they come just fit, but replacing drums with shallower offset ones (use same brake shoes) and welding on a new flange for backing plate to bolt on a little further out makes for plenty of room between brakes and springs.
---All pictures---
Re: Ring & pinion gears 49 3600 [Re: Hotrod Lincoln] #1243754
Sat Nov 18 2017 05:43 AM
Don huffer  Offline
Cape Coral Florida
Tanks for the reply. The 3:73s might be to much for my 216cid to push down the road.
Also the Eaton pumpkin swap is far easier to do and it gets me the 4:11s that work best for my hp.
Don
Re: Ring & pinion gears 49 3600 [Re: Grigg] #1243755
Sat Nov 18 2017 05:50 AM
Don huffer  Offline
Cape Coral Florida
Grigg
Thanks for the reply but that’s sounds like too much work for me.
Don
Re: Ring & pinion gears 49 3600 [Re: imstilllarry] #1243762
Sat Nov 18 2017 12:13 PM
Grigg  Offline
Lexington, VA
You’re welcome
The 4.10 swap is easy.
For a little more work and some welding the 14 bolt has several advantages, something to keep in mind.
---All pictures---
Page 2 of 3 1 2 3
Moderated by  SWEET
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
