The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Come one; Come all
14th Annual Stovebolt Reunion
In Kansas City, MO
September 8 and 9
Check for details and sign on!!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
44 registered members (52vff, 5 Window 9434, 52 6400, 53RLT56, 3B, 3 invisible), 582 guests, and 3 spiders.
Forums47
Topics112,430
Posts885,308
Members41,090
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 2 of 2 1 2
Re: Should I consider an exterior Sun Visor? [Re: grossie73] #1243337
Wed Nov 15 2017 12:27 AM
Tiny  Online
Global Mod
South Central Kansas
Allow me to be the devil's advocate. I have a Fulton on my '38 and love it. It does in fact make the interior cooler in that it blocks some of the solar radiation from coming in the windshield. Some left hand traffic turn signals can be blocked so a viewer can help. I have one on my '38. The clam shell type of viewer mounts to a garnish molding screw so there's no need to drill holes to mount it. There will indeed be four small holes to be drilled in your door jamb for mounting the visor. Don't drill them into the drip rail as I've seen some done. I personally do not like the sleepy sombrero look that the stock mounting brackets provide so I made an extended center support bracket arm to get the front of the visor up. Be sure to mount it with about a two inch gap across the trailing edge to let air out.
Re: Should I consider an exterior Sun Visor? [Re: Tiny] #1243341
Wed Nov 15 2017 12:53 AM
fonz8261  Offline
Michigan
You may want to consider a 1953 GM truck visor that was made for GM by Dieterich. It does not require any drilling of holes. It clamps to the driprail. I installed one on my '48 Chevy 1/2 ton. A detailed visor album is in my Photobucket picture file.
Good luck with your choice.
LUKE
Re: Should I consider an exterior Sun Visor? [Re: grossie73] #1243375
Wed Nov 15 2017 08:27 AM
Cosmo  Offline
ODSS President
CHARLOTTESVILLE
I've had my Fulton visor on for almost 20 years and over 100 k miles. Re-read that sentence if you like. I agree with Tiny regarding the solar radiation, that part is very real. One analogy would be walking around on a sunny day without a visor on a hat, it can be done but how much easier is it to shield the sun from your eyes?
Cosmo
Re: Should I consider an exterior Sun Visor? [Re: grossie73] #1243384
Wed Nov 15 2017 12:57 PM
Tiny  Online
Global Mod
Below are some images of my Fulton. Two show the dog bone mounting and two the finished product.
Re: Should I consider an exterior Sun Visor? [Re: grossie73] #1243405
Wed Nov 15 2017 04:11 PM
grossie73  Offline OP
Savage, MN
Nice hearing both perspectives, thank you! I'm going to check out all your photos and Luke's album and give this some serious thought.
1950 Chevrolet 3600 3/4 Ton Pickup
"HOGGRRR" - Grandpa & Uncle GRRRR's Truck
A Picture of the '50
More Chevy Pics
Re: Should I consider an exterior Sun Visor? [Re: grossie73] #1243409
Wed Nov 15 2017 04:25 PM
fixit1958  Offline
Myrtle Beach, South Carolina
grossie73,
Just finished installing an original 800 series Fulton visor on my '49 3100. Took a lot of prep work, sanding, priming, sanding, painting to match the Mariner Blue and color sanding and buffing. Turned out great and I too like the look. I also agree that the visor helps to reduce the radiant heat form the sun through the windshield. Use heavy blankets or packing blankets on the roof and hood and cowl during installation to prevent scratches and dents. It also helps to have a few extra hands during the install too help center the visor and start the nuts, screws and brackets. Installed mine by myself, but I'm sure it took me at least twice the time.
Tim
1970 VW Beetle
Re: Should I consider an exterior Sun Visor? [Re: grossie73] #1243475
Thu Nov 16 2017 02:37 AM
Samantha  Offline
Central Florida
My 54 3100 was bought new with one installed (I talked with the original owner some years ago) and it was on it when I bought it. I love the look and would not want to remove it. Yes, it restricts vision upward some, but like other things with our trucks, you adapt and/or get used to it.
Samantha
Re: Should I consider an exterior Sun Visor? [Re: grossie73] #1243495
Thu Nov 16 2017 09:02 AM
Dusty  Offline
Canterbury , NewZealand
I agree with Samantha , it is something you can get used to . Just like the modern cars with their forward slanting A pillars that are a terrible blind spot (well my wifes' PT is) so too the dip of the head to have a wee look somewhere becomes just something you do.
Yep , got a visor on my '40.
ps; my visor is a little similar to Lukes , in that I have made brackets to clamp the drip rail , so no holes drilled in the cab.
Re: Should I consider an exterior Sun Visor? [Re: grossie73] #1244565
Sat Nov 25 2017 05:19 AM
1950Styline  Offline
Tucson AZ
I removed the exterior visor that came with my ‘50 Styline. Big improvement in visibility. Can see traffic lights, clouds, sky, etc.
Page 2 of 2 1 2
Moderated by  Fourbrads, HandyAndy
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
