We are still asking:
What did you get done on your Bolt today ????
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures and No BOTS.
So ...
What did you get done on your Bolt today????
Oh Lord, I just gotta find it....
Forums60
Topics127,492
Posts1,031,907
Members45,792
Most Online1,229 Jan 21st, 2020
 Fire Extinguisher Recall
OP
Ex Hall Monitor
Kidde has issued a recall for dry powder fire extinguishers. Some go clear back to the '70s. If you have a dry power extinguisher in your vehicle, home or shop go <HERE> and take the link to find out if yours is included. I discovered both of ours (home and '38) are part of the recall and have free replacements on the way. If you have a small one in your vehicle the print on the label is very small so have a magnifying glass handy. Also the location of the model numbers and serial numbers in the graphics they show on the web site aren't always accurate for all models so be prepared to try more than one number. For example the date code on my small one is supposed to be 10 digits long but was only four (1993). Once I included six additional numbers on the other edge of the label it worked. They were all on the same line but not connected as a single number. They have a phone number to speak with a live person if you need help. Also Kidde makes extinguishers under other brand names so if your's isn't a Kidde, check it anyway.
Save a life, adopt a senior shelter pet. The three main causes of blindness: Cataracts, Politics, Religion. Let's go Jared! Name your dog Naked so you can walk Naked in the park.
 Re: Fire Extinguisher Recall
Thanks for the info Tiny. I also have an affected Kidde fire extinguisher. Went through their simple process, and supposedly a new one will arrive at my door in about 2 weeks. We'll see...
OP
Ex Hall Monitor
Pretty important info. It would be a bad day if you needed it and it didn't work. There are probably a lot of us with them in home, the garage and the vehicle. If you don't have at least one in each you need to get one.
Pretty important info. It would be a bad day if you needed it and it didn't work. There are probably a lot of us with them in home, the garage and the vehicle. If you don't have at least one in each you need to get one. Agreed. I just registered 3 recalled ones at work and two at home (one in the daily driver truck and another for the camper). Have a couple of others that are not affected. For the older ones without the long date code, but just a 4 digit date, you can just omit the date code entry. If you put in anything other than 5 digits it chokes. One of mine was 1991 and another 1994. I've had to use a fire extinguisher on a van that had an engine fire going down the road. 3 or 4 of us pulled over to help out. They were unloading their stuff to save it from a complete loss, but we got the fire out before the whole van went up.
Kevin Newest Project - 51 Chevy 3100 work truck. Photos [ flickr.com] #2 - '29 Ford pickup restored from the ground up. First car '29 Ford Special Coupe Busting rust since the mid-60's
ODSS President
Just submitted two for the recall, Thanks to Tiny!
Cosmo
"...my good horse Rocinante ('49 Chevy Half Ton), mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes
ODSS Lawman
Just wanted to bump this topic back to the top. I checked all my fire extinguishers last night and 2 out of 3 were effected. New ones on the way.
SWEET Sergeant At Arms Old Dominion Stovebolt Society BUNS?!?!?! Where we're going, we don't need no buns..... 1950 GMC 450 (25% owner)1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery [ stovebolt.com]
Mixed Up
Thanks Chris! I checked mine and don't have any Kiddi fire extinguishers. Never trusted such an important tool with the name Kiddi. I have used about four over the last 40 years. Saving other folks cars. Never got reimbursed for any of them.
One time I needed one and it did not have any pressure in it. Unscrewed the handle and shook out the powder, to put the fire out. So save the old ones, just in case you need a backup plan.
Don
OP
Ex Hall Monitor
You might want to check them anyway Don. They produce other brand names, that are part of the recall, as well.
Mixed Up
Thanks Tiny, I will today.
Don
I have two in my 55 pickup, both were recalled. I am waiting on the replacement extinguishers. Anybody received theirs yet? And what do they want you to do with the old ones?
