The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Indianapolis
Fabrications
Talk to Randy Domeck
See what they
can do
for you
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
26 registered members (49 3100, 69Cuda, 3100Cummins, 2manyprojects, 4 invisible), 513 guests, and 3 spiders.
Forums47
Topics111,055
Posts874,344
Members40,714
Most Online940
Apr 5th, 2017
Image Posting Policy
truck size #1238993
Thu Oct 12 2017 10:45 PM
Aus42blackout  Offline OP
Rockhampton, Queensland, Austr...
Hi all, well I have been talking to the son of the original owner off my truck after it was sold post WW11 and he has said that the truck was rated as a 6 ton truck.
I have the original service manual and it only rates the truck at 1 1/2 ton ????
Some specifics on my truck: 1942 1 1/2 ton ???
: 216 cc and 4 speed box
: 160" wheel base
: single axel
:single speed diff with duel wheels
: The flat bed is 12 ft with 10 boards across
Quick note is that the truck is part of the blackout series that was built in Detroit as a R/H drive (sent to Australia) to help with war effort in 1942
I would just like to make sure i have all my info correct
Hope you can help
Cheers Justin
Re: truck size [Re: Aus42blackout] #1238998
Fri Oct 13 2017 12:13 AM
tclederman  Online
Boltergeist
Jarvisburg, NC
12,000 load weight, or GVW?
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 47 years
1954 3104 5-window pickup w/Hydra-Matic
Z-series (54/55) GMC 350 (2-ton) COE
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: truck size [Re: Aus42blackout] #1239009
Fri Oct 13 2017 01:39 AM
EdPruss  Offline
Longmont, CO
20 inch tires?
Ed
'52 GMC 630 w/ 603 gasser, ex fire truck.
Re: truck size [Re: Aus42blackout] #1239032
Fri Oct 13 2017 10:17 AM
TGP  Offline
Metro East IL.
I don't see how that can be a 6 ton truck.
Ton and a half truck empty weight of approx.. 7500/8000 lbs.
Depending on the bed.
Maybe a GVW of 12,/13000 lbs. JMO
Tom
Re: truck size [Re: Aus42blackout] #1239152
Sat Oct 14 2017 01:01 AM
yes 20" tires
thanks guys I think I will just stay with the 1 1/2 ton load rating because of what I know about truck ,and there is not a lot off info about the blackout trucks in Australia to verify numbers
cheers
Re: truck size [Re: Aus42blackout] #1239248
Sat Oct 14 2017 07:29 PM
spanky  Offline
burlington, n.c.
If it is a Canadian built, and imported truck, it could actually be rated a little higher than a GM U.S. built truck, of the same size. I've noticed by collecting GM truck literature through the years, the Canadian built trucks, are rated higher/gvw, and Military trucks lower/gvw. I(s it a Chevrolet, or GMC ?
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Re: truck size [Re: Aus42blackout] #1239264
Sat Oct 14 2017 11:12 PM
52vff  Offline
Brantford, ON, Canada
My 52 Canadian Chevrolet 1700 is rated at GVW of 17600 lbs, but is considered a 3 ton. What model is yours? As Spanky said above the Canadian built models had different ratings.
1952 Chevrolet 1700 Bickle Seagrave
the fire truck
Re: truck size [Re: Aus42blackout] #1239331
Sun Oct 15 2017 05:47 AM
My is a USA built chevy, frame number is 42 D 4409-4(R or B) 739, model number is 4409 and the contract numbers from war are W-398-QM-12981 and W-398-QM-13006. I am not sure if the contract numbers help ID truck size ?????
Cheers Justin
Re: truck size [Re: Aus42blackout] #1239538
Mon Oct 16 2017 09:53 PM
32vld  Offline
Hauppauge, New York
Some Canadian Chevy trucks were called maple leafs. Some of that era
were 2.5 and 3 ton.
There were a few long WB 160" 1.5 trucks made in the Art Deco years.
VIN number should reveal what model truck you have. Jeffrey
Re: truck size [Re: Aus42blackout] #1239543
Mon Oct 16 2017 10:51 PM
69Cuda  Online
Big Bolt Forum Moderator
Seattle, Wa.
newer trucks, 4409 would be a 4400 model, or a 1.5 ton.
Mike
1955 Chevy 6400 ex-flatbed (no bed now!)
Moderated by  69Cuda, Grigg
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
