The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Indianapolis
Fabrications
Talk to Randy Domeck
See what they
can do
for you
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
6 registered members (AlpineBolt, Mike Attewell, Dusty, TPR57C, Chuck53, Richard H.), 66 guests, and 4 spiders.
Forums47
Topics109,534
Posts861,153
Members40,457
Most Online940
Apr 5th, 2017
Image Posting Policy
Dually suspension track #1238913
Thu Oct 12 2017 03:04 AM
RedBear  Offline OP
Moderated
Texas
I have a 1950 chevy truck and thinking about making it into a hauler , wrecker . Buy putting it on a 1970 1 ton dually frame with a Ls engine that I have. The only thing that concerns me is the front 1 ton suspension. I am thinking by doing this, the front stock dually wheels will stick out of the wheel wells. similar to most 4 wheel drives. But that's not what I want. Rather have them under the fenders. Normal looking. Also use the dually wheels to match the rear. I had plenty of ideas. But I am not sure what will work. Like using the suspension from a single wheel one ton, or 3/4 ton. then using front adapters to match the bolt pattern. As I remember the single 1 ton and the 3/4 ton do not have as wide of a track as a dually. Also seem like the 1 ton spindles and hubs are a lot wider then single wheel and 3/4. making the track wider. Anyone done something similar ? Or have Ideas.
THANKS !
Re: Dually suspension track [Re: RedBear] #1244592
Sat Nov 25 2017 02:06 PM
Whitedog  Offline
IL
Off hand, I’m going to say the later chassis will be a little wide. The 4100 and larger trucks had wider and longer fenders. It may be worthwhile to find a “Big Bolt” donor. I’ve also seen the low rider guys narrow their control arms. Unless you’re bagging it, I would guess it would create a terrible ride.
Is your 1950 a 3800 truck? In my opinion, the 3800 trucks are beefier than even the late model trucks.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Re: Dually suspension track [Re: RedBear] #1244611
Sat Nov 25 2017 04:00 PM
EdPruss  Offline
Longmont, CO
AD front fenders can be widened by a good 'tin man' by just adding a 3 or 4" piece in the flattest spot. Way lot safer and easier than shortening control arms.
Ed
Re: Dually suspension track [Re: RedBear] #1244670
Sun Nov 26 2017 02:47 AM
Hotrod Lincoln  Offline
Boltergeist
Dellrose, TN
Use the front sheet metal off a 1 1/2 ton or bigger truck. The fenders are wider to begin with, the wheel openings are larger, and the same trick of adding a strip of metal to the fender in a fairly straight section can be done with the wider fenders if necessary.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Dually suspension track [Re: RedBear] #1244756
Mon Nov 27 2017 04:03 AM
Grigg  Offline
Lexington, VA
I measured 1.5 or 2 ton AD front fenders (on the truck) to be 72" wide inside to inside of the lip at the bottom edge both front and rear of the wheel opening. Don’t have my notes handy for the small trucks.
I’m thinking the fenders aren’t actually much or any wider on the AD big trucks compared to the small ones.
Until you get up to the 400 series GMC, those fenders are noticeably wider.
1952 Chevrolet 3800 pickup
---All pictures---
Re: Dually suspension track [Re: RedBear] #1247796
Fri Dec 22 2017 12:19 PM
tntrucknut  Offline
Morristown,Tn.
Grigg,if you look between the headlight and grill on the 1 ton and 1.5 ton you can see the difference.
_____________
Floyd
If we choose being kind over being right,we will
be right every time.
Knowledge is a poor substitute for experience.
Remember what is precious to another, may not be to you, but it
is precious nonetheless.
1948 Chevy 2-Ton
Re: Dually suspension track [Re: RedBear] #1247861
Sat Dec 23 2017 01:49 AM
Grigg  Offline
Lexington, VA
Measuring my 1 ton same as I did the 2 ton it’s about 69-70” inside lower lips of front fenders (not most accurate, measured by myself).
So the 1.5 and 2 tons are about 2-3” wider under front fenders than the little trucks.
Not much.
---All pictures---
Moderated by  Grigg
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
