The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Indianapolis
Fabrications
Talk to Randy Domeck
See what they
can do
for you
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
27 registered members (49 3100, 69Cuda, 3100Cummins, 2manyprojects, 4 invisible), 512 guests, and 3 spiders.
Forums47
Topics111,055
Posts874,344
Members40,714
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 4 of 8 1 2 3 4 5 6 7 8
Re: 1959 GMC Shortbox Custom Wideside Deluxe [Re: FootStomper] #1204168
Mon Feb 13 2017 07:30 PM
FootStomper  Offline OP
Alberta, Canada
More blasting, priming and now some welding. Lower hinge pocket needed some cage nuts installed and cab corners needed some stitch welds too. Closed up the hinge pillars too.
more priming and some welding too
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
Re: 1959 GMC Shortbox Custom Wideside Deluxe [Re: FootStomper] #1205141
Mon Feb 20 2017 10:29 PM
Alberta, Canada
Did some detailing on some emblems with Autosol metal polish. Turned out pretty good but nothing can be done about the pitting short of replating... so that's what's getting done.
Click here for some before, during and after pictures
~~ Darcy
FootStomper
Re: 1959 GMC Shortbox Custom Wideside Deluxe [Re: FootStomper] #1213198
Sat Apr 15 2017 04:51 PM
Alberta, Canada
Cab mostly done and now mounted on the frame.
Cab on frame
~~ Darcy
FootStomper
Re: 1959 GMC Shortbox Custom Wideside Deluxe [Re: FootStomper] #1213273
Sun Apr 16 2017 01:37 AM
Achipmunk  Offline
Boltergeist
Boiling Springs, S. C. 29316
Looking good FootStomper. Nice looking work.
Pictures in my Photobucket
52 Chevy Panel
Re: 1959 GMC Shortbox Custom Wideside Deluxe [Re: FootStomper] #1216367
Sun May 07 2017 07:49 PM
Alberta, Canada
Got handy with my stainless. Having never worked with it before I think I did pretty good.
Stainless steel trim repairs and polished
before and after polishing stainless trim
~~ Darcy
FootStomper
Re: 1959 GMC Shortbox Custom Wideside Deluxe [Re: FootStomper] #1216368
Sun May 07 2017 07:55 PM
Alberta, Canada
Test fit the replacement fenders and ended up deciding to use the originals as they fit far better. The door gap was a deciding factor as you will see in the attached image.
test fit fenders and then media blasted
~~ Darcy
FootStomper
Re: 1959 GMC Shortbox Custom Wideside Deluxe [Re: FootStomper] #1216369
Sun May 07 2017 07:59 PM
Alberta, Canada
The rear diff got freshened up with Rustoleum Roc Prime and Sierra waterborne primer and paint. Sprayed very nice!
The split exhaust manifold my dad made got a bead blast then the Eastwood hot application cast iron paint treatment.
Split exhaust and rear diff painted
~~ Darcy
FootStomper
Re: 1959 GMC Shortbox Custom Wideside Deluxe [Re: FootStomper] #1237780
Wed Oct 04 2017 08:14 PM
Alberta, Canada
Summer is closing here in Alberta so getting back to the truck.
Sheet metal is done and we are getting into some painting now.
Sheet metal work done and now some paint!
~~ Darcy
FootStomper
Re: 1959 GMC Shortbox Custom Wideside Deluxe [Re: FootStomper] #1237818
Thu Oct 05 2017 01:50 AM
Achipmunk  Offline
Boltergeist
thumbs_up thumbs_up I like color with a little "color" to it. You da man.
52 Chevy Panel
Re: 1959 GMC Shortbox Custom Wideside Deluxe [Re: FootStomper] #1237923
Thu Oct 05 2017 07:00 PM
Alberta, Canada
High build primer sprayed out on front fenders and grill.
Primer
~~ Darcy
FootStomper
Moderated by  HandyAndy, John Milliman
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
