The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (Hotrod Lincoln, Gabes-trucks, Lightholder's Dad, fabuloco, Dragsix, 1 invisible), 266 guests, and 3 robots.
Forums50
Topics120,001
Posts961,099
Members43,533
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Trans Cover ID
#1236550 Tue Sep 26 2017 10:02 PM
Hey Bolters, I need some assistance identifying this Trans Cover. I bought it some years ago from a fellow Bolter for my '59 when I opted to install an SM-420 Transmission. It fit onto the floor but didn't match up to the gear shift location. Also, the gas pedal holes were cross ways and it doesn't have a hump. It's like the flat type for a column shift light duty truck. I suspect it came from a big bolt truck but not sure what. Can anyone help please? I'm putting it up for sale and just need to identify it. See pics. Thank you.
Pic-1
Pic-2
Re: Trans Cover ID
Hellomrwilson #1236563 Tue Sep 26 2017 11:11 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Cab Over?šŸ›
ā€˜65 Chevy Biscayne 4dr 230 I-6 one owner (Iā€™m #2)
ā€˜39 Dodge Businessmans Coupe
USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one!
Re: Trans Cover ID
Hellomrwilson #1236564 Tue Sep 26 2017 11:20 PM
well, it IS a 5-9 cover for a column shift, but with the hand brake slot it would be a 1T and up, shift hole could be for a "PowerMatic" if it doesn't match a 420
Re: Trans Cover ID
Hellomrwilson #1236618 Wed Sep 27 2017 01:58 PM
Thanks Bill, I'm not at all familiar with the "PowerMatic". Is it an automatic transmission for a big truck? If so, the flat cover versus hump style would be correct for it?
Re: Trans Cover ID
Hellomrwilson #1236626 Wed Sep 27 2017 02:52 PM
ace skiver
It looks like the Powermatic transmission was a 6-speed automatic used on big trucks in 1959 (6000-10000 series).
On different size trucks, it was used a 6-cyl (261) or 8-cyl engines (maybe 248 &/or 283 &/or 322?).
http://chevy.oldcarmanualproject.com/chevyresto/59ted11.htm
http://chevy.oldcarmanualproject.com/chevyresto/59ted13.htm
Is there a colored ID tag on the transmission?
http://chevy.oldcarmanualproject.com/chevyresto/59tsn04.htm
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Re: Trans Cover ID
Hellomrwilson #1236627 Wed Sep 27 2017 02:52 PM
yes, 6 speed automatic for 2T, just a thought because of the different shifter hole paired with the driveshaft brake
Re: Trans Cover ID
Hellomrwilson #1238151 Sat Oct 07 2017 03:36 PM
Guys sorry I'm late getting back to your replies.
Tim, I bought the cover for my '59 truck when I switched over from 3'sp column with an SM-318 to a 4 speed on the floor.
The seller couldn't tell me what it came out of and I bought it from the pictures, based on the shifter hole and E-Brake slot since I have an E-Brake on the SM-420.
I acquired some learning from that. First, that a humped version of the cover was required for my SM-420!
I just need to get this cover out of my garage and wanted to identify it properly.
I'd love to see a pic of this type of cover used with the "Powermatic" and E-Brake in a big bolt. Does anyone have one they could share?
Thanks again!
Moderated by  69Cuda, Grigg
