source What UBBCode can I use in my posts?
The following tags are available for your use if UBBCode is enabled:
Text Formatting
text = Makes the given text bold.
text = Makes the given text italic.
text = Underlines the given text.
text = Will post your text with a line through it (strike through).
text = Makes the given text red. <---------- this code here
text = Makes the given text green. text = Will change the size of the text to whatever size value you specify.
text = Will post your text with the specified font.
Matraca - my 1965 Chevrolet C10 long wheel base step side
60-66 Trucks : Read The Manual
Find answers for your 1960-1966 truck questions.
it is showing the code for the colors... in my signature line... I had it like that for years with no problems.
Maybe the colors for signatures have been turned off?
Just curious.
-W
