The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Indianapolis
Fabrications
Talk to Randy Domeck
See what they
can do
for you
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
4 registered members (tomctomc, Jay Zed, 2 invisible), 363 guests, and 3 spiders.
Forums47
Topics111,089
Posts874,625
Members40,722
Most Online940
Apr 5th, 2017
Image Posting Policy
Alignment spec's / stock 52 3100 #1234650
Wed Sep 13 2017 08:36 PM
52pu  Offline OP
York State (New York)
Having the 52 3100 1/2 ton aligned again next week at a different shop. Did not get a print out. I don't think they knew what they were doing. New tie Rod ends, roller bearings, king pins are good. Corvette 8 " wheels. Wanders a bit, quite a handful, no wear on front tires. My Chevy truck shop manual sais; Caster 1+3/4 +/- 1/2, Camber 1 +/- 1/2, Toe in 1/16 - 3/16. I've see other specks on stovebolt. Am i good with these if the new shop knows what to do?
"drugs are money, money is power, power is security"
Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
Re: Alignment spec's / stock 52 3100 [Re: 52pu] #1234658
Wed Sep 13 2017 09:14 PM
tclederman  Offline
Boltergeist
Jarvisburg, NC
front-end/alignment settings
Standard/original-style front-end parts?
What PSI in the tires?
What tire size on those wheels?
If all else fails (or, the alignment shop says all the alignment settings are good) decrease the PSI by 1 psi and go for a run/ride to test the steering. Too high pressure often causes wandering.
Continue by 1PSI decreases until the steering gets good or until it gets tough to steer.
If it gets tough before it gets good, the problem is not tire pressure.
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 47 years
1954 3104 5-window pickup w/Hydra-Matic
Z-series (54/55) GMC 350 (2-ton) COE
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: Alignment spec's / stock 52 3100 [Re: 52pu] #1234663
Wed Sep 13 2017 09:25 PM
Justhorsenround  Offline
Grease Monkey
Central, Oklahoma
Fat wheels/tires on a vehicle designed for skinny wheels/tires will wander and could be a "handful". If the new shop is a shop specializing in OTR trucks and has the equipment to properly bend what needs bending your alignment will be a success. You will still wander.
'62 Chevy C-10 Stepside Shortbed
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: Alignment spec's / stock 52 3100 [Re: 52pu] #1234667
Wed Sep 13 2017 10:09 PM
Hotrod Lincoln  Offline
Boltergeist
Dellrose, TN
Be sure the sector gear preload is adjusted properly, either by the spring scale method on the steering wheel suggested in the shop manual, or by going for a 10 inch/lb. increase in turning torque at the steering shaft nut in the center of the steering wheel as I've been doing for almost 60 years. Also be sure the wheels are pointed straight ahead when the steering gear is centered, which they should be if the drag link is straight and in good condition and the steering arm at the LF wheel the drag link attaches to at the front isn't bent. Most wandering problems are caused by a sloppy steering gear preload, although the huge oversized tires (and probably incorrect wheel offset) are mistakes that can't be corrected with wheel alignment.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Alignment spec's / stock 52 3100 [Re: 52pu] #1234689
Thu Sep 14 2017 12:44 AM
truckernix  Offline
Bracebridge Ontario Canada
If you have a chance to borrow a set of original type wheels and tires to put on the front, you may find your problem. I can tell you that with my 1 Ton, it steers really nicely with no wander or surprises.
1951 1 Ton Completed
Re: Alignment spec's / stock 52 3100 [Re: 52pu] #1234692
Thu Sep 14 2017 12:55 AM
52pu  Offline OP
Steering issues began after first alignment shop, even with the 8 " wheels. TIre size P235/70 R 15. AIr Pressure 28. All standard steering parts and it's not lowered, stock ride height. Drag link not bent.
Kent Heiner
Re: Alignment spec's / stock 52 3100 [Re: 52pu] #1234694
Thu Sep 14 2017 01:02 AM
52pu  Offline OP
I will try lowering the air pressure before next week alignment. And thanks Jerry for the selector gear preload tip. Truck drove good before the first alignment.
Kent Heiner
Moderated by  SWEET
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
