The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Indianapolis
Fabrications
Talk to Randy Domeck
See what they
can do
for you
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
26 registered members (52Chevy3100, 54hydramaticFL, 3100Cummins, 53 green 1- ton, 55 SHAKER, 6 invisible), 462 guests, and 3 spiders.
Forums47
Topics111,420
Posts877,336
Members40,796
Most Online940
Apr 5th, 2017
Image Posting Policy
Installing ford 9" in 1954 3100 #1199316
Wed Jan 11 2017 08:34 PM
Alex Jensen  Offline OP
Moderated
Green Bay, WI
I have a few questions for anyone who has already installed a ford 9" under there 54 chevy. preferably guys who are running 9-10" wide tires in the rear. Wondering what all goes into this and if I will have to tub, or what the housing width would be. just trying to save some time by mocking everything up. no reason to reinvent the wheel when this has been done 100s of times. Thank you in advance.
Re: Installing ford 9" in 1954 3100 [Re: Alex Jensen] #1199516
Fri Jan 13 2017 06:07 AM
coilover  Offline
Plano, Tx
Measure the width of your bed on the underside where if fits down over the frame. Add 2" to that measurement and then bolt your wheels/tires onto the rear end. If is less than this figure between the insides of the tires it's too narrow. Now measure from outside to outside on the tires and then from outside fender bead to outside fender bead. If the tire width measurement is wider than the fender to fender figure it's too wide. Check into spacers and wheel back spacing to see if you can position the tire for inside/outside clearance. On 10 inch tires one usually has to jack up by the bumper or frame to remove tire.
Evan
Re: Installing ford 9" in 1954 3100 [Re: Alex Jensen] #1229755
Sat Aug 12 2017 07:09 PM
BigBlockCameo  Offline
Courtenay BC Canada
You will find that most of the newer 9 inch rearends are wider than the stock 1/2 ton rear end. They may still fit, but if your truck is
lowered, you may have clearance issues with the fenders. My son has a 9 inch rearend from a late 60s Mustang that worked
great with no narrowing. I am using a 9 inch from a 73 Station Wagon, which is longer and I will have to shorten it ti fit.
There are also two different outer bearing sizes, so if you are looking for heavy duty, you will want the rear with the
larger bearings. Additionally, there are two types of splines, the 28, and the 31. The 31 spline rear end will take more
horsepower.
I should add, that the station wagon rear end actually has a larger crown and pinion, but the 9 inch pumpkin
fits with no problem. (assuming the splines match)
This link below, is an encyclopedia of the Ford 9 inch, and there are more links at the bottom
of his page.
Bob
http://www.kevinstang.com/Ninecase.htm
Last edited by BigBlockCameo; Sat Aug 12 2017 07:14 PM. Reason: add more information
55 Cameo 396 TH 400 with overdrive
65 Caliente conv
67 BB Caliente conv
67 Mercury 1 Ton
76 GMC 3/4 ton 454ci
84 Buick Turbo Regal
Re: Installing ford 9" in 1954 3100 [Re: Alex Jensen] #1229811
Sun Aug 13 2017 02:11 AM
EdPruss  Offline
Longmont, CO
The 28 and 31 splines mentioned are axle splines where the axle fits into the spider gears.
Ed
'52 GMC 630 w/ 603 gasser, ex fire truck.
Re: Installing ford 9" in 1954 3100 [Re: Alex Jensen] #1229830
Sun Aug 13 2017 09:28 AM
coilover  Offline
Plano, Tx
If you haven't bought a rear end yet you might consider using an Explorer. It is an 8.8" instead of a 9" but has held up well behind 1500hp engines. The mega horsepower engine guys weld the axle tubes to the center section and use a "C" clip eliminator kit but no rework is necessary for any tire that will fit inside an AD fender. It is 59.5" wide so a 1" spacer is needed to match your old rear or you can use a 1" adapter to match the front wheel bolt pattern. If you choose a disc brake one the E-brake drum is inside the rotor so the cable is just like your old one which is a real plus. Very plentiful selling in the $150-$250 range and is a leaf spring rear end so not a lot of extra brackets to cut off.
Evan
Moderated by  KCMongo
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
