The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Indianapolis
Fabrications
Talk to Randy Domeck
See what they
can do
for you
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
6 registered members (AlpineBolt, Mike Attewell, Dusty, TPR57C, Chuck53, Richard H.), 66 guests, and 4 spiders.
Forums47
Topics109,534
Posts861,153
Members40,457
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 603 of 627 1 2 601 602 603 604 605 626 627
Re: What did you get done on your bolt today???? [Re: BIG CHEVY 3600] #1229057
Tue Aug 08 2017 02:21 PM
sleepindawg  Offline
NE Kansas, USA
Trying to include my old sigstat turn signals/hazards switch into an E-Z wire 12 circuit harness...Oh my head hurts!
Tim
1950 3600 Some Pictures
1951 3100
1952 3100 Some Pictures
Re: What did you get done on your bolt today???? [Re: BIG CHEVY 3600] #1229064
Tue Aug 08 2017 02:46 PM
Justhorsenround  Offline
Grease Monkey
Central, Oklahoma
'62 went to the alignment/brake shop this morning. New brakes all the way around. Decided to farm out that job to the pros. I was surprised at how well it drove and rode, except for trying to go to the right barrow ditch when you applied the brake.🛠
'62 Chevy C-10 Stepside Shortbed
'48 Chevy Suburban Street Rod
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: What did you get done on your bolt today???? [Re: BIG CHEVY 3600] #1229828
Sun Aug 13 2017 06:31 AM
Woogeroo  Offline
Socket Breaker
Tool Box
In the past month or so on my '65 Chevy C10 :
had new exhaust put on by the professionals.
had a oil leak with the nylon hose for the Oil PSI gauge, the hardest part of fixing that was getting to it, it is next to the distributor on a SBC and sorta under that indented area in the firewall.
Noticed the diff. was leaking, I *think* from the gasket cover... so I replaced it today, still have to top off the fluid. The instructions on the goop box said to let cure for 24 hours... so here are a few in progress action shots:
3 pics - rear axle differential gasket cover replacement - in progress shots
Happy riding and wrenchin' folks,
-W
Re: What did you get done on your bolt today???? [Re: BIG CHEVY 3600] #1229829
Sun Aug 13 2017 08:23 AM
Dusty  Online
Canterbury , NewZealand
I had a nasty vibration develop recently .
Turned out the front U joint coupling bolts had come loose ............
Dodged a bad one there smile
Re: What did you get done on your bolt today???? [Re: BIG CHEVY 3600] #1229980
Mon Aug 14 2017 05:19 AM
Woogeroo  Offline
Socket Breaker
Tool Box
Dusty - I know that exact feeling!
on my '65 long bed, it has a two piece drive shaft, the one in the center doesn't last very long. grin
I filled up the differential on the rear axle today on the old '65 c10 after putting the cover back on yesterday.
pump pump pump. Those little gear oil pumps are handy folks. grin
Took it for a little spin.
Yay. grin
-W
Re: What did you get done on your bolt today???? [Re: BIG CHEVY 3600] #1229989
Mon Aug 14 2017 09:48 AM
jockbolter50  Offline
Scotland
Finally got the truck in the garage to replace the failed 4 link mounts only to discover the left hand axle tube has fractured nearly 360 degrees,the crack had followed a ground down weld left over from the removal of a previously offending,poorly engineered 4 link set-up.!
That might explain why I was getting an oil leak (I thought the vent was at fault initially)and a strange intermittent vibration from the rear end which i'd chalked up to the pinion angle being slightly off due to the aforementioned mounts which had cracked along the full length of a TIG weld. (Both sides,a year apart did this)
I'm horrified to think what could have happened had the whole thing let go......
I just with this truck would stop biting my 'A'.
More pix on Flickr .
Re: What did you get done on your bolt today???? [Re: BIG CHEVY 3600] #1230375
Wed Aug 16 2017 04:00 PM
Grease Monkey
Central, Oklahoma
Got the '62 C-10 back from the shop. Now stops in a straight line instead of heading to the ditch. All new brake parts front and back with the exception of the parking brake hardware. It was missing when I bought the truck and I haven't had any luck finding parts. Installed the new cat whiskers in the doors. Windows no longer rattle. Baby steps.🛠
Re: What did you get done on your bolt today???? [Re: BIG CHEVY 3600] #1231153
Sun Aug 20 2017 11:22 PM
Roland  Offline
Ramsey
Put on front wheel cyclinders, brakes hoses, master brake cyclinder and found antifreeze leak. I might be driving it on Friday for 1st time since I inherited it 11 years ago.
Roland
46 Chevrolet 3/4 ton in Minnesota
Re: What did you get done on your bolt today???? [Re: BIG CHEVY 3600] #1231330
Mon Aug 21 2017 10:33 PM
Grease Monkey
Central, Oklahoma
Removed the gas tank on the '62 C-10 in preparation for the new tank which arrives tomorrow. When I emptied the gas there was so much rust I'm surprised the engine ran at all. Replacing tank and sending unit along with the lines tank to carb.🛠
Re: What did you get done on your bolt today???? [Re: BIG CHEVY 3600] #1231776
Thu Aug 24 2017 01:45 PM
Grease Monkey
Central, Oklahoma
New tank in and plumbed. Anouther checked off the list.🛠
Moderated by  Justhorsenround
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
