The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Indianapolis
Fabrications
Talk to Randy Domeck
See what they
can do
for you
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
36 registered members (1951Chevy1Ton, 66flea, 3B, 55 SHAKER, 6571, Achipmunk, 1 invisible), 448 guests, and 4 spiders.
Forums47
Topics109,578
Posts861,550
Members40,461
Most Online940
Apr 5th, 2017
Image Posting Policy
Matraca - my 1965 Chevrolet C10 long bed step side #1179622
Thu Aug 25 2016 12:46 AM
Woogeroo  Offline OP
Socket Breaker
Tool Box
Hi folks.
This is my old iron that I drive all the time :
Matraca - 1965 Chevrolet C10 long bed step side
It is beat up and rusty, but it is mine and I like it.
You view the Gallery & Projects section to view various photos I have taken of many different areas when asking questions online. Also I have taken photos along the way of a few fixes or projects I have undertaken over the years.
2003 to current...
Check it out if interested.
Take care and happy wrenching,
-W
Re: Matraca - my 1965 Chevrolet C10 long bed step side [Re: Woogeroo] #1200176
Wed Jan 18 2017 02:12 AM
juspassinthru  Offline
ga
I love it cool ol truck
It aint a hobby it's a lifestyle!
LIFERS C.C.
Re: Matraca - my 1965 Chevrolet C10 long bed step side [Re: Woogeroo] #1204784
Sat Feb 18 2017 01:25 AM
Woogeroo  Offline OP
Socket Breaker
Tool Box
Finished this up today...
02/17/2017 – add a fuse block
-W
Re: Matraca - my 1965 Chevrolet C10 long bed step side [Re: Woogeroo] #1204848
Sat Feb 18 2017 03:34 PM
Cosmo  Offline
ODSS President
C'ville,VA,USA,Earth
-30 = constant [positive (+)] power (usually wired directly to car battery)
-85 = coil ground (wired to the negative (-) battery terminal or any grounded metal panel in the car)
-86 = coil power (wired to the control source. could be a switch, or it could be the car's IGN or ACC circuit.)
-87 = switched [positive (+)] power output. (when the relay coil is powered, lead/pin 87 is connected to lead/pin 30)
Woogeroo, I'm going to make my own relay and fuse accessory panel using your painless relays to switch on power to the accessories.
Thanks for the contribution.
Cosmo
Re: Matraca - my 1965 Chevrolet C10 long bed step side [Re: Woogeroo] #1214455
Mon Apr 24 2017 10:14 AM
Woogeroo  Offline OP
Socket Breaker
Tool Box
Hiya fellow Stovebolters...
so, after diagnosing charging issues... ordering and installing a new voltage regulator...
I had to replace my heater core again, so I took lots of photos.
Here is the latest tech article if you are interested in checking it out.
04/19/2017 – heater core replacement - 44 pictures
Happy Wrenching,
-Woogeroo
Re: Matraca - my 1965 Chevrolet C10 long bed step side [Re: Woogeroo] #1229827
Sun Aug 13 2017 06:29 AM
Woogeroo  Offline OP
Socket Breaker
Tool Box
In the past month or so :
had new exhaust put on by the professionals.
had a oil leak with the nylon hose for the PSI gauge, the hardest part of fixing that was getting to it, it is next to the distributor on a SBC and sorta under that indented area in the firewall.
Noticed the diff. was leaking, I *think* from the gasket cover... so I replaced it today, still have to top off the fluid. The instructions on the goop box said to let cure for 24 hours... so here are a few in progress action shots:
3 pics - rear axle differential gasket cover replacement - in progress shots
Happy riding and wrenchin' folks,
-W
Re: Matraca - my 1965 Chevrolet C10 long bed step side [Re: Woogeroo] #1229979
Mon Aug 14 2017 05:16 AM
Woogeroo  Offline OP
Socket Breaker
Tool Box
Today I filled up the differential... pump pump pump... then I put the bolt back in the side there.
Took it for a little test ride.
Yay.
-W
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
