The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Indianapolis
Fabrications
Talk to Randy Domeck
See what they
can do
for you
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
4 registered members (miraclepieco, mtn. man, tomctomc, carryall jerry), 363 guests, and 3 spiders.
Forums47
Topics111,394
Posts877,098
Members40,790
Most Online940
Apr 5th, 2017
Image Posting Policy
1937 truck horn and fuel gauge #1229434
Thu Aug 10 2017 02:25 PM
dalef62  Offline OP
Moderated
PA
Hello,
I am new here and I am working on a 1937 truck with a 12 volt conversion. It has an alternator and turn signals, and I am installing a new wiring harness.
I have a few questions, one is, how does the horn connect at the button. I got a new rubber button and cap and it has a hard wire unit that mounts in the rubber that goes down into the steering column. Where does the wire connect and what makes the contact?
The second question is, Do I need a Runtz resister on the fuel gauge? It is the original gauge and a new 12 volt sending unit. And if I do, where should it be placed? on the positive side of the gauge or between the gauge and the sending unit?
Thanks for the help!!
Dale
1937 Chevrolet Truck
Re: 1937 truck horn and fuel gauge [Re: dalef62] #1229730
Sat Aug 12 2017 03:33 PM
dalef62  Offline OP
Moderated
PA
Anyone have any ideas??
Re: 1937 truck horn and fuel gauge [Re: dalef62] #1229733
Sat Aug 12 2017 04:11 PM
baldeagle  Offline
Server Fixer
Richardson, TX, USA
I don't know the specifics of the '37, but, in general, horns have one wire. The horn ring, when the horn is depressed, completes the circuit by making ground. So, the horn would have two wires going to it. One is hot, tied to the battery directly (or indirectly - but hot all the time), and the other is a ground wire that goes to the horn ring. This is a pdf of the wiring for a '37. http://chevy.oldcarmanualproject.com/electrical/wiring/pdf/37truck.pdf
Paul Schmehl CI 12
geek@stovebolt.com
Stovebolt Staff: Geek
1948 Chevy 3100 Five Window
Re: 1937 truck horn and fuel gauge [Re: dalef62] #1229766
Sat Aug 12 2017 08:48 PM
46Sparky  Offline
USA
Yes, there is a single, ground wire that runs from the mast bearing in the steering column down to a port at the bottom near the steering box. That wire has a plug-in type connector to join with the wiring harness. There is a wire, 12 gauge (?) in the harness with one end leading to the horn for power and another wire, for the continuation of the ground connection to the horn.
If your truck was converted to 12 volt and powered up before a resistor was installed, the fuel gauge sending unit might be already damaged. The wiring instructions for a Runtz resistor are included with the package when purchased. The resistor is attached to the lug on left side (door side) of the fuel gauge. If your truck has other accessories, a resistor will be needed for each one.
Re: 1937 truck horn and fuel gauge [Re: dalef62] #1229879
Sun Aug 13 2017 04:49 PM
Tiny  Offline
Global Mod
South Central Kansas
OK Dale, you have one of THESE in your mast jacket (steering column). It is called the Mast Jacket Bushing. The steering mast (shaft) passes through the center bushing. The wire you see exits the jacket under the hood, just above the steering gear box. That wire connects to the horn ground circuit.
You also have THIS ASSEMBLY that mounts inside the hub of your steering wheel. The "S" wire passes through two holes in the center hub of the steering wheel. The rubber bushing attaches to the "S" end of the "S" wire and fits into a groove in the steering wheel hub. The cap then fits on top of the rubber bushing.
When you push on the horn button, the "S" wire travels through the holes in the SW hub and makes contact with the copper ring on top of the bushing. At the same time the "S" wire contacts the edge of the hole(s) of the SW hub, completing the ground and makes the horn honk. It's not the best system but it works....most of the time.
All of the above is assuming the '37 truck is the same as my '38 coupe. If it's not I apologize for muddying the water & I'll go stand in the corner and mind my own business.
Re: 1937 truck horn and fuel gauge [Re: dalef62] #1229889
Sun Aug 13 2017 05:47 PM
46Sparky  Offline
USA
The photos look like I what I recall seeing in my '37 1/2 ton truck too.
Moderated by  Rusty Rod
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
