The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Positive thinking ...
We are still asking:
What did you
get done on
your Bolt today
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt
this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures
and No BOTS.
So ...
What did you get done on your Bolt today????
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (FrankenChevy, 55shaker, DavidBraley, Justhorsenround, Bill Trotter, 1 invisible), 80 guests, and 4 robots.
Forums60
Topics127,506
Posts1,032,027
Members45,793
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
51 GMC 256 engine
#1227824 Mon Jul 31 2017 04:24 PM
mcannon Offline OP
Getting Ready to paint my motor will epoxy paint work on the intake and exhaust manifold or high heat paint. Tks Mike
Re: 51 GMC 256 engine
mcannon #1227829 Mon Jul 31 2017 04:40 PM
Maybe on the intake - it would most likely burn/flake off the exhaust.
256 engine (1940/1941)?
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
tclederman #1227831 Mon Jul 31 2017 05:19 PM
mcannon Offline OP
Thank You, Mike
mcannon #1228075 Wed Aug 02 2017 01:27 PM
I believe SPI Epoxy is good up to 450*f or so...
Give me ambiguity
or give me something else
CASO #1228080 Wed Aug 02 2017 01:45 PM
How hot do you think a Stovebolt's exhaust manifold gets?
- at idle?
- at sustained 55 mph?
SPI epoxy primer?
Tim
mcannon #1228123 Wed Aug 02 2017 05:35 PM
U
mcannon I would use bees wax on the exhaust after it was warmed, or a produced exhaust "dressing", but not a "paint-type" product. The porosity of cast iron would allow for a decent painted finish only if there was never a drastic temperature change.
I am going to attempt to season my exhaust like a Lodge cast iron skillet this time. That's the best example I can think of.
I already gave the "high heat" paint companies their chance. That stuff just makes a lot of choking smoke happen when it's burning off. How hot does the Stovebolt exhaust manifold get???
Dayum hot.
Brad
Wrench Fetcher, PhD
Uncle Brad #1228145 Wed Aug 02 2017 07:49 PM
mcannon Offline OP
sounds like a great idea, Thanks, Mike
mcannon #1228149 Wed Aug 02 2017 08:17 PM
U
Calyx is the brand (I think?) of produced manifold dressing most often used. I think folks here have had some great results with it. It is easy touch-up from what I hear.
I will post my exhaust coating experiment here in the coming weeks.
Brad
Edit : it is Calyx
Wrench Fetcher, PhD
mcannon #1228151 Wed Aug 02 2017 08:34 PM
calyx manifold dressing (exhaust and intake manifolds)
It has to be easily "redressed" every year or two. This is very easily done with a toothbrush, with the manifold in-place
https://www.youtube.com/watch?v=xw4iKr1YllI
It is not quite so quick-and-easy. I did the "first coat" on a manifold/set off the engine, after media-blasting the manifold/set (just the exhaust manifold, or, both manifolds). You do not have to have bare metal (off the truck). You should, however, removed all grease and flakey-metal from the manifold.
Here is another description of application.
Tim
mcannon #1228184 Thu Aug 03 2017 12:47 AM
I am a big fan of Calyx.
Page 1 of 2 1 2
Moderated by  HandyAndy, klhansen
