The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (Tommy, olezippi, Jimmie D, ttoaster, Tiny, 1 invisible), 96 guests, and 3 robots.
Forums50
Topics119,530
Posts957,022
Members43,424
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Is my granddad's GMC 1/2 tonna 54 or 1st series 55?
#1220323 Wed Jun 07 2017 01:55 AM
WTexas Offline OP
Moderated
I wanted to know if anyone could hell me decipher
if the build plate reveals a
102-24 S Z3675
Re: Is my granddad's GMC 1/2 tonna 54 or 1st series 55?
WTexas #1220366 Wed Jun 07 2017 03:49 AM
Open drive line would be 55 closed driveline 54
Pictures
41 Chevy
41 GMC
46/7 Chevy
41 Plymouth
41 Chevy coe
WTexas #1220368 Wed Jun 07 2017 04:09 AM
ace skiver
The Z series was 1954-1955 New Design GMC.
Approximately analagous to Chevrolet Advance-Design 1954/55st.
GMC differed from Chevrolet trucks in using a series letter rather than a year.
What are the engine serial number and the engine/head date codes?
Here is info on decoding the GMC truck serial number.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE [1954advance-design.com] - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
WTexas #1220374 Wed Jun 07 2017 04:28 AM
That low serial number would have been built in 1954.
My TRUCKS website
WTexas #1220419 Wed Jun 07 2017 04:26 PM
Remember that factories were famous for using up inventory when series or years changed, resulting in trucks that were "change over exceptions".
WTexas #1220424 Wed Jun 07 2017 04:39 PM
ace skiver
102-24 would be a 1/2 ton longbed (Chevrolet trucks did not have longbed 1/2 ton trucks in that series).
Most likely you have an open drive-line/drive-shaft, whether 54 or early 55.
Tim
WTexas #1220451 Wed Jun 07 2017 08:51 PM
Did the 55.1 long bed have the u-joint enclosed in the ball, or were they exposed modern u-joints?
WTexas #1220454 Wed Jun 07 2017 09:37 PM
ace skiver
I do not know.
But, if the 55.1 GMC long-bed driveshaft was the the same as a 55st Chevrolet 3600 (same bed length), it had a fully open driveshaft (as the Chevrolet 3600 had for the first time in 1954).
Tim
WTexas #1220551 Thu Jun 08 2017 05:03 PM
From the 1954 GMC shop manual (I'll assume your copy is on order):
Model 101-22 has single a torque tube
Model 102-22 has split enclosed shafts connected via U-joint, rear shaft is identical to 101-22
Series 150-22 Front shaft is solid, rear is tubular. U-joint trunnions have needle bearing support rings.
Series PM150-22 AND UP Both shafts are tubular with the needle bearing trunnions.
When two shafts are used, there will be an extra crossmember with a center bearing supporting the front shaft.
I don't know what changes were made between the 54 and 55.1 versions of GMC trucks, but a lack of torque tube on a half ton may be the best evidence of a later model. You will find much arcane GMC knowledge at www.oldgmctrucks.com
If you can't laugh at yourself, I'll laugh at you.
Panel Beater: 1955 1st Series GMC 250-22
Moderated by  Justhorsenround
