The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 members (66flea, 55shaker, Chiana River, Donf, 7045george, 2 invisible), 136 guests, and 2 robots.
Forums60
Topics124,936
Posts1,008,317
Members45,097
Most Online1,229
Jan 21st, 2020
Image Posting Policy
carrier bearing adjustment
#1219690 Fri Jun 02 2017 01:27 AM
Skooter Offline OP
I understand tightening the right adjuster to force the left bearing up against its race. Then the manual says to tighten the right adjuster "snugly" against the bearing, then tighten it an additional notch or two to "preload" the bearings.
One or two notches past "snug" seems pretty tight to me. Maybe I need help to understand the concept of preloading the the carrier bearings, which bathe in gear oil, as opposed to front wheel bearings (only 33 ft/lb if I recall??), which doesn't seem as tight as preloaded carrier bearings would be.
Or just follow the manual to the letter no matter how tight it seems?
2 Chronicles 7:14
1952 Chevy 1/2-ton 3100
Dalton Highway survivor
www.truckwithaheart.com [flickr.com]
Re: carrier bearing adjustment
Skooter #1219706 Fri Jun 02 2017 03:03 AM
One notch after contact will be just right. It will put a slight preload on the brgs.
1972 Chevy c10 Cheyenne Super
Skooter #1219827 Sat Jun 03 2017 02:26 AM
Skooter Offline OP
Thanks, just needed some verification I'm reading it right. Guess typos in the manual are not unheard of, this must not be one of 'em.
1. Tighten
2. Back it off
3. Tighten again
Basically what it says.
2 Chronicles 7:14
Moderated by  SWEET
