The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (Gazz, Hookalatch, GMCJammer51, FoodTrucker, 3B, 1 invisible), 293 guests, and 3 robots.
Forums60
Topics123,387
Posts995,753
Members44,653
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: My 54's hiccup.
WE b OLD #1218961 Sun May 28 2017 12:06 AM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Sorry, meant to post this in the engine forum. Senioritis! ohwell
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily”
‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one!
Re: My 54's hiccup.
WE b OLD #1218964 Sun May 28 2017 12:33 AM
Reposted in the engine.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck in the Gallery
2017 Buick Encore
Pix on Photobucket
Re: My 54's hiccup.
WE b OLD #1218967 Sun May 28 2017 12:43 AM
235-6. bored 20 over, dual carbs Rochester.b. Mini hei from Langdon's. Thanks for the suggestion about the spark plug. I have a tester that lays on the wire and it lights up if there is electricity going through the wire. And no I will not hold on to it. It looks like a pencil with an angled slot cut out of it, I have had it for years. If I post back tomorrow you will know I survived. wink Couldn't wait. I ran a wire from the plug wire then to a 12volt test light and cranked it no light came on. What would happen if i hooked the wire to the coil wire and just turn the ignition on????
2017 Buick Encore
Pix on Photobucket
Re: My 54's hiccup.
WE b OLD #1219043 Sun May 28 2017 06:09 PM
I had a 72 Monte Carlo and had the points distributor changed out for an hei unit. The car would run and then shut off for no reason. Turned out it was a bad distributor. Also check the coil.
Joe
Re: My 54's hiccup.
WE b OLD #1219048 Sun May 28 2017 07:19 PM
Thanks, that is the symptom. I have done all I can. will have to call my mechanic. I thought I had kept the old distributor but after nine years I am not really sure. I looked but did not find it and some parts I gave away.
2017 Buick Encore
Pix on Photobucket
Re: My 54's hiccup.
WE b OLD #1219057 Sun May 28 2017 08:50 PM
Too bad about those fancy replacement distributors.
I have never had a problem with standard points/distributors or with the two Pertronix units (6v and 12v) that I have been using for 15+ years. Nonetheless, a spare distributor with adjusted-points is in my "travel kit".
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Re: My 54's hiccup.
WE b OLD #1219069 Mon May 29 2017 12:29 AM
I called the mechanic and he is going to make a house call Tue. or Wed.
2017 Buick Encore
Pix on Photobucket
Page 2 of 2 1 2
Moderated by  Bouncer, Justhorsenround
