The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 members (Dusty53, 49nut, exgenius, Brad Allen, JackieC, 46paneltruck), 161 guests, and 3 robots.
Forums50
Topics120,997
Posts969,982
Members43,811
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
1961 235 oil weight and quantity?
#1216887 Thu May 11 2017 09:45 PM
Hello!
My goal this spring is to get ol' Gertrude tuned up and happy. She is in desperate need of an oil change.
What weight oil is a good year round oil? She doesn't get driven enough to require much more than bi-annual semi-annual oil change.
How much oil does my 235 require?
Anyone know a good place to get the old school canister oil filters?
Thank you!
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
Re: 1961 235 oil weight and quantity?
Fort Knox #1216888 Thu May 11 2017 09:51 PM
Lots of trustworthy sources here use a 15w-40 diesel oil.
Filter depends on what kind you have. Mine takes a Fram C4 or equivalent. Can't remember the wix number off the top of my head.
Fort Knox #1216890 Thu May 11 2017 09:59 PM
ace skiver
10W-30 was recommended by GM
10W-30, 10W-40, 15W-30, 15W-40 would be OK
bi-annual - every two years
semi-annual - twice a year
Factory recommendation: 2,000 miles
I usually change mine annually (once a year, in the Fall), unless I travel more than 2,000 miles in a year.
5 qts plus capacity of oil filter (if installed - 1qt or 2qt, usually)
Oil filter changed every 2,000 miles
There were many styles (brands/sizes/years) of filters that were used on 235s.
Do you have an owners manual and/or a Shop Manual?
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Fort Knox #1216892 Thu May 11 2017 10:08 PM
tclederman -
Thanks for the grammar edit, I fixed it above.
I have the owners manual somewhere. She has been in storage for a little over a year, still trying to sort out all my manuals and documents from a move / divorce. I know that dang manual is somewhere.
Does anyone run Lucas Oil Stabilizer? My 1993 GMC with the 6.5td loves that stuff.
Kyle
My Machine
Fort Knox #1216902 Thu May 11 2017 10:32 PM
ace skiver
Kyle,
I understand lost/hidden/stored manuals. I moved to NC around a year ago and I am still looking for manuals/documentation.
Regarding oil filter: you might find yours in this Stovebolt.com Tech Tip
Good luck with your truck.
Tim
Fort Knox #1216907 Thu May 11 2017 11:07 PM
Related question. The bypass filters were optional equipment. They add a quart of capacity. I believe it will drain to crankcase when not running.
Fair to assume dipstick will be inaccurate after engine sits a while?
Fort Knox #1216911 Thu May 11 2017 11:43 PM
ace skiver
GM optional 235 by-pass oil filters we usually 1qt, but a 2qt filter was also an option in many years.
One was on my 1954 3104 235 engine (RPO canister was painted black).
Tim
Fort Knox #1216916 Fri May 12 2017 12:20 AM
So what about the dipstick issue I mentioned?
Fort Knox #1216918 Fri May 12 2017 12:23 AM
The 15W-40 diesel oil lubricant is traditional oil from petroleum.
I've noticed that synthetic/traditional blend is 10W-40.
Pure synthetic is 5W-40.
I take that to mean synthetic is a much better lubricant at cold temperature and they can get away with a less viscous oil on cold startup.
I use 6 quarts 10W-30 Mobil One synthetic (NAPA 1072 bypass oil filter) in my 261 and now change it once a year although I could go much longer than that. It gives me a chance to crawl under my '48.
1948 3/4-Ton 5-Window Flatbed Chevrolet [sandeace.com]
28 Years of Daily Driving but now on hiatus. With a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
Fort Knox #1216920 Fri May 12 2017 01:05 AM
ace skiver
Put in 5 qts at an oil change and check the dipstick.
It should read at the mark.
If you have a 1qt oil filter (that drains back to the pan with the engine off), add one qt of oil.
Then, check the dipstick and scribe/mark it at the new level.
Tim
Page 1 of 2 1 2
Moderated by  Woogeroo
