The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
17 members (53 in Phoenix, Bill Trotter, BLUEMEANIE, 5 Window 9434, 55 SHAKER, 78buckshot), 115 guests, and 3 robots.
Forums50
Topics119,491
Posts956,753
Members43,414
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Turning engine by hand
#1214601 Tue Apr 25 2017 04:02 AM
jremig Offline OP
Ok, scenario...what is the best way to turn a motor over by hand? 235 motor with an 848 head. Hoping to use this motor for my 52, 3100. Motor is complete, all parts still attached except for valve cover which I removed. Is there a place to latch on to the crank for turning over the engine? A place to insert a bolt to put a wrench on? Or should I be able to grab the crank pully and turn it by hand?
Joe
Re: Turning engine by hand
jremig #1214602 Tue Apr 25 2017 04:09 AM
Boltergeist
Screw two 3/8-16 bolts into the harmonic balancer, into the puller attaching holes and use a pry bar between them. A better way is to use the chisel-shaped end of a shepherd's crook wrecking bar between the flywheel ring gear teeth and the edge of the bellhousing.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
jremig #1214630 Tue Apr 25 2017 01:35 PM
Make sure you don't have spark plugs in it.
jremig #1214640 Tue Apr 25 2017 02:23 PM
jremig Offline OP
Plugs are out and sitting on the work bench. Will try some grade 8 bolts on the balancer and see if I can't get it to turn
jremig #1214697 Tue Apr 25 2017 07:47 PM
Jerry's technique works great. I also have good luck using a flywheel turning tool if the engine isn't seized up. It's a tool that does what Jerry describes with the wrecking bar, but it locks itself into the flywheel instead of having to use the bellhousing for leverage. If you search 'flywheel turning tool' on eBay, you'll get several hits.
If you have the engine out, consider using one of Jerry's kits to tap the crank snout so that you can install the harmonic balancer with a bolt. Sure makes it easier to turn over the engine using the bolt.
Matt
jremig #1214703 Tue Apr 25 2017 08:03 PM
ace skiver
Jerry,
Do you recommend using the 216/235/261 crank-snout bolt to turn the engine through a full rotation?
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE [1954advance-design.com] - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
jremig #1214830 Wed Apr 26 2017 04:49 PM
Boltergeist
If it's one that's seized or hasn't been run in a while, NO! You will either strip the thread or break the bolt on a seized-up engine. If it's free to turn, no problem. The 7/16-20 bolt can take 70-75 ft/lbs of torque without a problem, which is much more than a running engine needs.
Some balancers have a squared-off hole in the front that will accept a 3/4" square drive socket extension. If so, that's the best way to turn the crank, using a 3/4 drive ratchet or a breaker bar.
jremig #1214963 Thu Apr 27 2017 03:45 PM
I just took off the flywheel protective cover underneath and grabbed the flywheel by hand (with shop gloves on) and it turns really easily, even with spark plugs in.
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
Moderated by  Woogeroo
