The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
29 members (51sub, 78buckshot, 47 BOMBER, Big Diehl, Barnfind49, 1 invisible), 105 guests, and 4 robots.
Forums47
Topics117,703
Posts941,707
Members43,027
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Rebuilt SM420 Novak
#1212900 Thu Apr 13 2017 05:51 AM
Hello all, just finished installing my rebuilt SM420 using Novak kit.
Everything went well, but I have a few issues
Before connecting the driveshaft, I have her a start to make sure everything was smooth. In neutral, I see the u-joint connector on the back of the tranny spinning a little. Clutch feels great, smooth shift all gears
But when I put in reverse, the u-joint connector rotates the same direction as 1st and 2nd
Also, when I did connect the u-joint, and in neutral, it act like it's in gear and I cannot push the truck
I did install new shift bushing and I think I read that the problem may be in the tranny cover with the rods not being aligned. I plan to call Novak tomorrow, but if anyone has advice before that it's much appreciated
1949 Chevrolet 3100 Suburban Carryall
"Bad Guy"
More pix in Photobucket
1950 Chevrolet 3100 3-Window
More pix on Photobucket
1966 GMC Suburban Carryall Custom
"Big Guy"
Re: Rebuilt SM420 Novak
Suburban Lou #1212905 Thu Apr 13 2017 07:09 AM
Big Bolt Forum Moderator
I would pull the bolts out of the top cover and see if you can lift it a tad and see if the shift forks are where they need to be. It sounds like something is not lines up properly.
with the top off, you should be able to make sure it is in neutral and spin the rear yoke by hand.
Mike
1955 Chevy 6400 ex-flatbed (no bed now!)
Suburban Lou #1213320 Sun Apr 16 2017 05:57 AM
Fox Offline
Lou,
I have a similar problem with my 420 where it rotates in neutral at the output shaft. My sneaking suspicion at the moment is the pilot bearing is egged from my installation. It was a bear to push into the crank and I think it's pinched. I'm going to pull the bearing and the 420 and try an old spare to see if it is the culprit. But for now I'm still sanding, sanding , sanding!
More pictures here
1951 GMC 9430 1 ton dually—-Shiny!
1970 Chevrolet C10 - Grandpa’s- My first truck.—in progress to shiny
1972 Chevrolet C20- rusted
1970 Chevrolet K20 Suburban—rusted.
1950 Chevrolet 1300- in progress to shiny.
Parts trucks-
1951 GMC 9300
1951-GMC 9430
1951- Chevrolet 1300
Suburban Lou #1213354 Sun Apr 16 2017 01:44 PM
Pilot bushings are cheap, way less than the grief caused by improper installation, check it upon first trans. Installation when it is easy to replace. Do a test fitting with a spare input shaft.
Ed
Suburban Lou #1213477 Mon Apr 17 2017 04:52 AM
Got it up and running today
Wrestled with the cover and smashed my finger by the shift did
Drove around for a bit
Very smooth and well worth the clutch and rebuild
"Bad Guy"
"Big Guy"
Suburban Lou #1214017 Thu Apr 20 2017 11:20 PM
I've had my Novak sm420 for over a year it's great. Had the rear end changed to 3:38 new u- joints and drive shaft and clutch assembly. Couldn't be happier Novak is a great company and nice people.
Steve
Moderated by  SWEET
