What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
Forums59
Topics128,597
Posts1,041,772
Members46,055
Most Online1,229 Jan 21st, 2020
OP
I just went to install my brand new, rather expensive powermaster alternator that looks just like the generator it is to replace. However the pulley is about 1/2" off as far as alignment, and the mounting pads are about !/4" too narrow. Just wondering if anyone else has had this problem, and how they conquered the situation. I can think of a couple of ways, one would be to simply mill the 1/4" off of the original mounting bracket, and slot or drill another set of holes in the original bracket to allow for proper alignment. But it sure seems to me for the kind of money they were asking they could have come up with something that was a bit closer to fitting.
You're on the right track with your idea of how to correct the problem, but first try turning the mounting bracket 180 degrees and bolting it back on. If that solves the pulley alignment problem you might not have to drill new holes, but you'll obviously need to adjust the length of the bracket some way.
If you don't want to alter the original bracket, a piece if 1" wide, 1/4" thick flat stock can be heated and bent into an original-appearing part and then drilled to fit. I promise not to tell anybody if you do that! LOL! Jerry
"Freedom's just another word for nothing left to lose" Kris Kristofferson Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self. Ernest Hemingway
WAG MORE- - - - - -BARK LESS!
OP
Oh, I realize it is a lot of money, however considering the amount I will have into this engine before I am done, what is a few hundred plus or minus. I gained some by turning it around, but I ended up drilling another set of holes, and taking 3/16" off the bracket. Quite an ordeal. But it looks good. I had done pretty well keeping everything 6 volt, but you can't run EFI on 6 volts.....
EFI on a stovebolt- - - - -really?
LOL! Jerry
Moderator - The Electrical Bay and Rocky Mountain Bolters
Please stay on topic. I removed a few off topic posts. Thank You.
Another quality post.
Real Trucks Rattle
OP
so anyway despite the difficulties, it is up and running again, the worst was the gas gauge, I had to drill out the itty bitty hole in the needle so it would sit farther down the shaft as it hit the "picture" frames inside the gauge panel. Then I couldn't get it to work, turns out there was a bad connection. but the starter sure does spin. It looks nice, I redid an old voltage regulator so it looks right, but it isn't actually a regulator anymore. got the nice 2 speed wipers while I was at it. Thinking about putting my stereo in it....when I got the truck it had an old tube radio in it. It ended up in the trunk of my old mercury meteor when it caught fire.
