The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (bluesman, Jon G, 81tta, AwDang, 59 fleet, 1 invisible), 256 guests, and 4 robots.
Forums50
Topics120,082
Posts961,740
Members43,550
Most Online1,229
Jan 21st, 2020
Image Posting Policy
3 Speed Pops Out
#1205075 Mon Feb 20 2017 07:01 AM
U
UnklRod Offline OP
My stock 3 Speed is popping out of 1st and 2nd while going down a hill. I have a three on the tree on my 57 truck. On flat roads it does fine. Any thoughts on what the problem is? While retoring the truck I bought and had a shop rebuild the tranny. I only have 2000 miles on the truck since the resto.
Thank you.
Jon
1957 Chevy 1/2-Ton Truck
More pix
The coldest winter I ever saw was a summer I spent in San Francisco M. Twain
If at first you don't succeed...skydiving is not for you!
If you don't like my carbon foot print, stick it up your Prius!!
Re: 3 Speed Pops Out
UnklRod #1205079 Mon Feb 20 2017 01:44 PM
Poppet springs weak, thrust washer(s) missing or installed improperly, shift linkeage not adjusted properly, mainshaft or c'shaft bearings worn.
Ed
UnklRod #1205092 Mon Feb 20 2017 04:09 PM
Boltergeist
If the shift linkage is adjusted properly, you need to find another transmission shop and get them to fix what the first guy messed up. Don't bother going back to the first guy- - - -he's already proved what he can and can't do.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Hotrod Lincoln #1205097 Mon Feb 20 2017 04:35 PM
Ed and Jerry are spot on with this tranny problem. Linkage,internal bearing wear, or a worn main shaft will cause the tranny to pop out of gear. Had an early Muncie 3 speed in my 1958 Chevrolet that would pop out of 3rd. Had a so called tranny shop rebuild it and it still did the same. Rebuilt it myself with all new bearings and main shaft, adjusted the linkage to FSM specifications and no more problems.
Tim
1970 VW Beetle
UnklRod #1205102 Mon Feb 20 2017 05:11 PM
All of the above are causes. A worn front u-joint will also create problems. Popping out of 3rd gear is a common problem with these transmissions. There is a fix which places a spacer between the front bearing and the gear. You must also remove the spacer on the first row of needle bearings for this to work. This moves the gear further into the syncronizer. pre68Dave has info on this on his site also.
Popping out of 2nd and 3rd indicates to me that all of the above could be in play. In any event a replacement syncro drum and the 2-3 shift fork are in order.
Fred
UnklRod #1205107 Mon Feb 20 2017 05:18 PM
These transmissions almost never jump out of 1st or 2nd if the linkage is adjusted correctly.
My Blog
UnklRod #1205457 Thu Feb 23 2017 02:10 AM
Rebuilt mine almost 40K miles ago, it's been fabulous except the column shifter has always shaked/bounced a lot in 2nd. Just keep a hand on it to steady it, and it's never acted like it wanted to pop out of gear. Probably could stand linkage adjustment?? but never stay in 2nd long enough to take my hand off the shifter, so never considered it much of a problem.
2 Chronicles 7:14
1952 Chevy 1/2-ton 3100
Dalton Highway survivor
www.truckwithaheart.com [flickr.com]
Moderated by  SWEET
