The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
21 members (DaveV, Green_98, 3100Cummins, Fred Jones Jr, 4 invisible), 135 guests, and 3 robots.
Forums50
Topics120,493
Posts965,751
Members43,684
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Can anyone ID this 2-speed rear?
#1204005 Sun Feb 12 2017 05:57 PM
This (currently disconnected) 2-speed rear end belongs to my wife's 1941 GMC 2.5 ton (CC403). Originally a fire truck, the Department disconnected it, leaving it in low range, since they had no one left who could operate it (1990's - kids today lol!). Seem like high range would be handier if I had to pick just one, for road speed (45 mph). Anyone know what it is?
Brad
https://drive.google.com/file/d/1SmV9NMuCNZJUmyxVRTwDcWsSMoiA3xLqsg/view?usp=sharing
https://drive.google.com/file/d/1XT9dkrCqTYlErzGf_c45xoIsw4P12SUnrw/view?usp=sharing
Re: Can anyone ID this 2-speed rear?
Brad Johnson #1204012 Sun Feb 12 2017 06:30 PM
It looks to be manually operated. Most ive worked with were electric or vacuum. You could disconnect the lever from the cable & see if The high side works or if it is in fact on the low side. If that changes it to the high side you could wire it in that position or hook up the cable & repair it to work.
1956 Chevy 1/2-Ton Pickup
Brad Johnson #1204103 Mon Feb 13 2017 05:09 AM
Whatever it is, the ratios are slow and slower, so, look for some modern 2 speed with higher ratios. 2 speed axles are usually listed or stamped on housing by high ratio only.
Ed
Brad Johnson #1204126 Mon Feb 13 2017 01:33 PM
As Wrenchbender said, it is mechanically shifted like the transmission. If the lever is still in place, it should not be hard to hook back up. Shifting it will take some learning, but it will be a skill to show off.
Brad Johnson #1204152 Mon Feb 13 2017 05:25 PM
3B Offline
Hy Brad Johnson, that is a double reduction Timken differential very heavy duty and heavy. This was the standard axle for your truck, hope that helps.
Moderated by  SWEET
