The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Points to Ponder
LOVE STRUCK!
You might be a Stovebolt Lover
Check the New Stuff and Announcements Forum
What do you think?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
0 registered members (), 355 guests, and 1 spider.
Forums48
Topics117,308
Posts937,978
Members42,896
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
snow chains - newbee needs advice #1204114 Mon Feb 13 2017 08:24 AM
Drmike Offline OP
hi guys, i discovered the hard way that the firestone white walls on my truck render it undrivable around my new place. tyres just spin on the smallest hint of snow/ice.
most folks around here seem to be using snow chains.
ive never used them before so seeking a bit of advice.
has anyone used snow chains on the AD truck? any fitment/clearance issues? any recommended make? (stock 49 3100) any advice appreciated.
cheers
Re: snow chains - newbee needs advice [Re: Drmike] #1204124 Mon Feb 13 2017 01:26 PM
Ed Hotaling Offline
While I never have driven an AD truck, I have used chains a lot. You want chains that fit your tires. There are a few types of cross chains. The V-bar get excellent traction on ice, but are murder on pavement and just dig deeper in mud. The plain cross chains are best for all-around use. They will work in snow or mud and won't tear up the road too badly.
My advice is to find out where folks in your area buy theirs and go there. The fenders on your truck should have plenty of room for clearance, just buy chains sized for your tires.
Re: snow chains - newbee needs advice [Re: Drmike] #1204125 Mon Feb 13 2017 01:26 PM
Cosmo Offline
ODSS President
You buy them for your tire size so it's plug and play. Disclaimer: I have radials. I have a set of cable chains that I have used, easy to put on/take off. There are a host of questions to ask like: How far is your commute? What speeds will you be driving? Does the climate merit snow tires for the winter? Does the community lay down salt, brine or sand?
Snow tires on all four corners is recommended. Letting some air out of your tires will give you a larger contact patch with the pavement.
Cosmo
"...my good horse Rozinante ('49 Chevy Half Ton), mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes
Re: snow chains - newbee needs advice [Re: Drmike] #1204127 Mon Feb 13 2017 01:40 PM
EdPruss Offline
One needs to add additional weight to the rear of the truck, chains or not, get a 2 x board that fits across the bed to hold your weights behind the rear axle, 500 lbs. would be great.
Ed
Re: snow chains - newbee needs advice [Re: EdPruss] #1204128 Mon Feb 13 2017 01:47 PM
Cosmo Offline
ODSS President
Ed
If you mean add weight just behind the cab in the middle of the truck, yes, if not, Ed, your advice is very wrong.
Cosmo
Re: snow chains - newbee needs advice [Re: Drmike] #1204163 Mon Feb 13 2017 07:03 PM
EdPruss Offline
Cosmo,
I do not agree with you.
Ed
Re: snow chains - newbee needs advice [Re: Drmike] #1204185 Mon Feb 13 2017 09:46 PM
Grigg Offline
Both sides of this disagreement aren't clear to me, perhaps not to others either.
Y'all tell me if my guesstimation is correct.
Ed prefers weight at the tailgate of the pickup, in which case that weight is more effective on the rear tires by lifting the front a little, more weight transfer to the rear a little less weight on the front tires.
Cosmo says put the weight at the front of the bed by the cab, or perhaps at least over the rear axle? This helps the rear wheels and will add weight to the front wheels if ahead of the rear axle.
Cosmo is concerned about loss of steering ability with the lighter front?
Ed understands that but in his experience there's already enough weight on the front for steering, enjoys even better grip at the rear?
I've seen it both ways, personally I put the weight at the tailgate and have had good success. I suppose if the front seemed extra squirmy I'd rethink.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Re: snow chains - newbee needs advice [Re: Drmike] #1204186 Mon Feb 13 2017 09:46 PM
Wrenchbender Ret. Offline
The further back the weight is in the bed the better the traction. It will make it handle a bit weird but small sacrifice for traction. Back in the 50's when we got stuck we put the tailgate down & had a buddy or 2 sit on it. Pull right out.
1956 Chevy 1/2-Ton Pickup
Re: snow chains - newbee needs advice [Re: Drmike] #1204197 Mon Feb 13 2017 11:03 PM
coilover Offline
I used to have an extra set of wheels and tires for chains only. Would let nearly all the air out of the tires, install chains tight on the soft tires and then air up. Made it so chains had zero slop.
Evan
Re: snow chains - newbee needs advice [Re: Drmike] #1204213 Tue Feb 14 2017 12:58 AM
Cosmo Offline
ODSS President
Did a quick search as we all did regarding traction, all the sources say do not place weight behind the rear wheels, most say place weight over the rear wheels, I found one that said distribute evenly in the bed of the truck.
My 'center of the truck' came from driver's ed. in upstate New York. There was a film or two that was shown where weight was placed in a cars trunk, on a slippery curve the car literally spun, the center of the car being the axis of rotation. The weight was then placed behind the driver in the center of the vehicle and on the same slippery turn the car did not spin.
Cosmo
Page 1 of 2 1 2
Moderated by  Justhorsenround
Powered by UBB.threads™ PHP Forum Software 7.7.3
