The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 members (GTOKID, Justhorsenround, Hambone, Jacket4256, Bill Trotter, dirtball), 53 guests, and 3 robots.
Forums47
Topics117,771
Posts942,313
Members43,039
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 13 of 16 1 2 11 12 13 14 15 16
Re: Tango's '46 Shorty Bus
Tango #1192534 Sat Nov 26 2016 04:43 PM
Tango Offline OP
Hey thanks Chip...great idea. Hope it doesn't offend anyone, just lookin for some ideas.
1946 1.5-Ton Chevy Shorty Bus
More pix on Flickr
All my best --- Tango
Tango #1194290 Thu Dec 08 2016 12:16 AM
Tango Offline OP
OK...so I got the move done, built some walls, shelves and a workbench and now I am finally back to working on the bus! The new space is great but relocating everything was a royal PITA...and expensive.
Going at the bus from several angles. Cut out more rusty metal and made room for an electrical box at the same time. Giving the floor a final going over and getting it down to clean metal by removing 70 year old asphalt and welding up a few more holes I have found. Then doing some more work on the dash/firewall and steering.
There are are a couple of pix of my attempt at body work and the hole for the electrical stuff on the album page below.
Album https://www.flickr.com/photos/tango88/albums/72157626526227672/page6
More pix on Flickr
Tango #1196336 Wed Dec 21 2016 09:35 PM
Tango Offline OP
Added a few pix to the album below of work done after the big move. Cut some big holes out then filled'em back in...removed some paint and put more back on...and added a bit more insulation.
More pix on Flickr
Tango #1200440 Thu Jan 19 2017 06:04 PM
Tango Offline OP
Still pluggin' away. Got all the rust replaced with new panels on the rear, built in a through-wall box for my electrical (house) panel, some interior walls and I'm now installing the mount for a set of freshwater tanks. As always...pix on Flickr below.
More pix on Flickr
Tango #1200515 Fri Jan 20 2017 04:01 AM
Great project smile thanks for the update .
Tango #1200516 Fri Jan 20 2017 04:05 AM
Boltergeist
Tango, thanks for the update. For a while I thought you had slipped out the back door smile Progress is progress. Keep on trucking brother.
Pictures in my Photobucket
52 Chevy Panel
Tango #1200943 Mon Jan 23 2017 02:15 AM
Tango Offline OP
Thanks guys. That's the plan...just keep pluggin' away. More to follow.
More pix on Flickr
Tango #1204488 Thu Feb 16 2017 01:40 AM
Tango Offline OP
Been doing a work all over the bus lately. Hoppin inside and out. Got some much needed sheetmetal that allowed me to start constructing the dash/firewall and mounting some of the stuff that will go through it. Steering, brakes, stuff like that. Added some sheet metal outside and some marine ply inside.
Posted some more pix in the Flickr album. Back to work.
More pix on Flickr
Tango #1208790 Thu Mar 16 2017 01:36 AM
Tango Offline OP
A few new updates. Made some progress on the footwell part of the new firewall along with working out the throttle & the TPS for the tranny. Pix in the Flickr album.
More pix on Flickr
Tango #1218246 Mon May 22 2017 04:41 PM
Tango Offline OP
Been sorting out the bits and pieces of a remote Hydroboost brake system. It is activated by a small (3/4") Wilwood clutch master. Don't really care for the extra plumbing required but there is simply not enough room under the hood to direct mount a conventional master.
A few pix of this Frankenbrake system in the album below.
More pix on Flickr
Moderated by  J Lucas
