We are still asking:
What did you get done on your Bolt today ????
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures and No BOTS.
So ...
What did you get done on your Bolt today????
Oh Lord, I just gotta find it....
Forums60
Topics127,470
Posts1,031,724
Members45,787
Most Online1,229 Jan 21st, 2020
 When did Chevy stop using Carburetors?
OP
Still mulling over which way to go with the 54 3100. Have not driven it enough yet to see what shape the 235 is in. Been cruising Craig's List to see what donor vehicles are out there and several questions come to mind. I don't want computer controlled engine or transmission. When did Chevy stop using carburetors on small block V8's?
 Re: When did Chevy stop using Carburetors?
Sir Searchalot
80'S Came with TBI, then 92 with FI, in general, of course, because they had mechanical FI in a 57 Chevy.(Corvette) The always right Wiki says "In the U.S. market, the last factory carbureted cars were the 1990 Oldsmobile Custom Cruiser & Buick Estate Wagon"
Watch out for careful drivers!!! I'm away on an ego trip. Will be back on Feb 30. I'm not an Auto Mechanic, but I play one on TV. I charge $0.02 for every opinion and I take Paypal. Plan B is always better than plan A, by definition. I recommend invoking MIL-T-FP41c when machining and fabricating I used to think beer was bad for me, so I gave up thinking. Sometimes no nonsense makes sense, in a sense. You can't teach a new dog old tricks. Honk if you're Amish
If this 8 decade old brain hasn't cross wired somewhere I think 86 still had a carb and 87 was TBI on a sbc.
Evan
The TBI truck SBCs were 87-95. I had a replacement 87-95 truck 350 crate long block in my Chevelle. Mine had an Edelbrock intake and carb on it, with a 700R4 behind it, and had no computer control at all.
My wife's uncle has a nice stock 81 Chevy or GMC pickup that has some sort of EFI badge on the tailgate, so there is some sort of fuel injection on it, but I don't know if it's "computer controlled" or not.
Regardless, aftermarket intake manifolds are cheap, and you should be able to easily put a carb on most any SBC running a distributor. Once you get into the LT1 and LS engines, I know there has to be something controlling the ignition, and I don't know if there's a simple way around that.
The last few years of carburetor production were in the 1980's with the electronic-controlled carbs. Those things were a nightmare, and had most of the same sensors as the TBI engines. Another attempt at complying with emission control requirements written by a bunch of politicians with no knowledge of science or engine design was computer-controlled spark timing, the infamous "ESC" system used on mid-80's Chevy pickups with 305 engines and Q-Jet carburetors.
Stay FAR away from any Quadrajet with a little blue 2-wire electrical connector in the air horn! Jerry
"Freedom's just another word for nothing left to lose" Kris Kristofferson Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
WAG MORE- - - - - -BARK LESS!
Sir Searchalot
A good motor to buy is a 1970-72. 454 BBC! Hard to find anymore. Pre smog and good HP. There are all kinds of good crate motors. There is no replacement for displacement.
You want a 1980 or earlier to have no computer. There were some carburetor engines up to about 1992 in the last full sized GM rear wheel drive station wagons. Though they will have computers.
I believe 1975 was the first year for electronic ignition.
Though non-HEI distributor can be used in 1975 and later engines and HEI distributor can be used in 1975 and earlier engines.
So you have from 1955 and up small block and 1958 and up large block. A lot of years and engine displacements to chose from. Jeffrey
If you choose the HEI ignition option, look for a unit with a vacuum advance and a 4-pin module. The ESC distributors with 5 or 7 pin modules must also have a computer, and the 5-pin ones are notorious for failing quickly. If there's a 4-pin oval connector attached to the HEI housing, with or without a vacuum advance, it's not a stand-alone unit. There's also a way to make the HEI reliable up to about 7K RPM or so, where the standard units start to spark-scatter at around 5500. That's another sneaky trick we used that my competitors in the "stock" round track class couldn't figure out. We always ran our engines 1,000-1,500 RPM faster than all our competitors, and the tech inspectors couldn't catch us. Jerry
Carburetion specialist
You could make the argument that for 6-cylinder engines, they stopped for several years after 1949! Jon
Good carburetion is fuelish hot air The most expensive carburetor is the wrong one you attempt to modify If you truly believe "one size fits all" try walking a mile in your spouse's shoes! [image] http://www.thecarburetorshop.com/Avatar.jpg[/image]
I heard that the CEO of Carter had the 1-millionth Chevy Rochester replacement carburetor gold plated and gave it to the boss at GM as an "I told ya so" present! Jerry
