The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 members (DRCA, TTC Restorations, Hotrod Lincoln, GeorgeCz, 2ManyTrucks, 1 invisible), 203 guests, and 3 robots.
Forums50
Topics121,403
Posts973,270
Members43,924
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Temp difference - front to back of block
#1189927 Mon Nov 07 2016 03:05 AM
DADS50 Offline OP
1950 chevy 3100
Engine
1954 235 z motor
Been driving the truck to work the last 6 weeks or so.
Ive noticed I've been puking just a little coolant and have to top off after about the 4th trip
Gauge reads normal. 160 with a 160 stat
Up to 180 going up the hill on the way home then levels off back to 160.
7lb cap
Raditor 4 years old , U.S. Radiator
Today when I got home I took temp reading with one of those laser deals
Front of block read 170
Rear of block read 195
Is this normal?
Re: Temp difference - front to back of block
DADS50 #1189938 Mon Nov 07 2016 03:33 AM
Boltergeist
Yes, probably. Try installing a coolant recovery tank so the overflow gets sucked back into the radiator as the engine cools down again. That can also be caused by keeping the radiator overfilled- - - -leave a couple of inches of expansion room in the top tank, with the coolant just above the level of the tubes.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
DADS50 #1190132 Tue Nov 08 2016 01:30 PM
DADS50 Offline OP
Just thought it was odd that this started happening after not driving much this summer.
I don't know what the danger temp is on the block
I hadn't had a need for a recovery tank since I put the truck back together in 2010
Should be simple to install
DADS50 #1190146 Tue Nov 08 2016 03:53 PM
It's almost universal in L6 engines since the incoming cold water reaches the front cylinder jacket first, and is warmed by each cylinder in turn as it passes down the block.
No easy cure, but it's been dealt with by Chrysler in the Spitfire and Cummins in the Dodge diesel.
DADS50 #1190150 Tue Nov 08 2016 04:22 PM
Boltergeist
A 7# cap raises the boiling point of the coolant to 233 degrees at sea level. If you're hearing gurgling in the system, that means at least some places inside the water jacket are getting a lot hotter than the laser is showing. Since the temp inside the cylinders approaches 2,000 degrees under load, that's not surprising. Just put a puke tank on the system, and stop obsessing about it. A dangerous overheat situation will result in a boil-over, not a little dribble of coolant.
DADS50 #1190163 Tue Nov 08 2016 05:43 PM
DADS50 Offline OP
Sounds good
Im not an experenced engine guy so Id thought Id ask
Moderated by  Woogeroo
