The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Some light reading
ENTERTAINING ADVENTURES
In the Stovebolt Reading Room
A little light reading
OR
Epic stories of old tin hunting!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 registered members (1962C10, triplep, truckernix, Spicoli01, panic, 2 invisible), 412 guests, and 3 spiders.
Forums48
Topics117,365
Posts938,470
Members42,915
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Transmission swap for 60 GMC #1174947 Fri Jul 22 2016 02:20 AM
60GMCFlat Offline OP
Howdy,
I have a 60 GMC flatbed, with 261 and 4 speed trans w/granny gear.... I want to pull my 18 foot food trailer... what automatic trans do I want behind my 261 ?
Whatever you are doing, have a good time at it..... Ya gotta do it anyway... So, enjoy life !!!!
Re: Transmission swap for 60 GMC [Re: 60GMCFlat] #1174949 Fri Jul 22 2016 02:21 AM
Also, I want to increase the power of the 261... should I go with dual carbs ? and headers ?
Re: Transmission swap for 60 GMC [Re: 60GMCFlat] #1175012 Fri Jul 22 2016 02:21 PM
Justhorsenround Offline
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
More info please. How far do you plan to pull, speeds, hills or flat land? 1/2 ton, 3/4 ton or 1 ton? How much does your trailer weigh? There is a right one we just need more info on how you plan to use it. secret
ā€˜65 Chevy Biscayne 4dr 230 I-6 one owner (Iā€™m #2)
ā€˜39 Dodge Businessmans Coupe
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: Transmission swap for 60 GMC [Re: 60GMCFlat] #1175068 Sat Jul 23 2016 01:02 AM
panic Online
I know people do it, but I towed a small boat & trailer behind a Dart (225" slant 6, 145 hp) and it was misery unless the road was downhill.
There is no conventional speed equipment that will add 50 hp (my opinion: minimum).
The most practical is probably a turbo (eBay: Chinese turbo from On3 for $500 new) since the engine can remain completely stock except for ignition timing and the oil lines. Only works when you put your foot down.
Re: Transmission swap for 60 GMC [Re: 60GMCFlat] #1175336 Mon Jul 25 2016 03:00 AM
EdPruss Offline
GMC's didn't come with a 261, perhaps it was swapped in? Is it a V6? I think they used 270, 302 through '62. A close ratio 5 speed with a 302 should be adequate.
Ed
Re: Transmission swap for 60 GMC [Re: 60GMCFlat] #1175347 Mon Jul 25 2016 04:04 AM
Cletis Offline
1960 was the first year of the V6. If it has a straight 6 it is not original to the truck.
My TRUCKS website
Re: Transmission swap for 60 GMC [Re: Cletis] #1175357 Mon Jul 25 2016 05:35 AM
canuck49 Offline
Maybe 60GMCFlat's truck is Canadian, then the 261 would be correct.
1954 GMC 9314
Re: Transmission swap for 60 GMC [Re: 60GMCFlat] #1175458 Tue Jul 26 2016 02:29 AM
Howies551Ton Offline
He lives in Washington state, The truck may have crept across the border just to confuse you yanks. Get that darn wall up!
Our light GMC trucks had Chevy running gear. All the body work was just like your GMC trucks.
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine
4 1966 Plymouth VIP 5.7 GenIII Hemi
5 1966 Imperial Crown Coupe 440 engine
Moderated by  Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.7.3
