The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 registered members (bluesman, DennisM, Andrew7dg, alemachevyman, gsharum, HandyAndy), 302 guests, and 4 spiders.
Forums47
Topics115,012
Posts912,544
Members42,077
Most Online940
Apr 5th, 2017
Image Posting Policy
'57 265 Chartreuse #1159860
Tue Apr 12 2016 12:59 AM
AtomicYJ  Offline OP
Washington
Does anybody have a paint code or source for the chartreuse color early '57 car engines were painted? Or does it pretty much have to be color matched? I haven't been able to find anything.
I want to paint mine that instead of gray.
1957 Chevy 3200
1971 Jeep CJ-5
1983 Chevy K-10
Re: '57 265 Chartreuse [Re: AtomicYJ] #1159864
Tue Apr 12 2016 01:41 AM
tclederman  Offline
Boltergeist
Jarvisburg, NC
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 50 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 14 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: '57 265 Chartreuse [Re: AtomicYJ] #1159908
Tue Apr 12 2016 04:52 AM
Mike B  Offline
Hughesville, MD
You will not find Chevrolet engine paint codes, they were never published. The best you can do is look at pictures of '57 cars with the 265 and see what shade works for you.
Mike B smile
Re: '57 265 Chartreuse [Re: AtomicYJ] #1160045
Tue Apr 12 2016 11:11 PM
AtomicYJ  Offline OP
Washington
Thanks for the replies. I kinda figured I'd be on my own. I have both those pictures and I really like the color of the first one. Guess I can try and find some place that can color match a picture.
1957 Chevy 3200
1971 Jeep CJ-5
1983 Chevy K-10
Re: '57 265 Chartreuse [Re: AtomicYJ] #1160469
Fri Apr 15 2016 02:52 AM
AtomicYJ  Offline OP
Washington
Is this anywhere close to the HD truck 261/265/283 engine yellow?
http://cdn.enginelabs.com/image/2015/01/on-the-cart-3.jpg
1957 Chevy 3200
1971 Jeep CJ-5
1983 Chevy K-10
Re: '57 265 Chartreuse [Re: AtomicYJ] #1160471
Fri Apr 15 2016 02:57 AM
tclederman  Offline
Boltergeist
Jarvisburg, NC
If you like it, go with it.
No one knows what shade is "correct".
Tim
Re: '57 265 Chartreuse [Re: AtomicYJ] #1160492
Fri Apr 15 2016 04:49 AM
Mike B  Offline
Hughesville, MD
From examples I have seen through the years I would say NO they are not the same color.
The 261 was yellow, kind of like this color;
http://www.crayola.com/explore-colors/unmellow-yellow.aspx
The 265 was Yellow Green, kind of like this color;
http://www.crayola.com/explore-colors/chartreuse.aspx
Put these two color pages side by side and you will see the green in chartreuse.
As Tim said, there is no right or wrong. This is just my opinion and it's not ment to stir things up, engine color mix info was never published.
Mike B smile
Re: '57 265 Chartreuse [Re: AtomicYJ] #1160632
Fri Apr 15 2016 10:00 PM
AtomicYJ  Offline OP
Washington
I'm not trying to stir things up or find the "one true" color. Just looking for something in the realm of close enough. I just want to paint my motor something other than gray, and would like to use a color that was used on some kind of truck engine. Thank you for the replies.
1957 Chevy 3200
1971 Jeep CJ-5
1983 Chevy K-10
Re: '57 265 Chartreuse [Re: AtomicYJ] #1160990
Mon Apr 18 2016 01:20 AM
Howies551Ton  Offline
Gleichen/CalgaryAlberta
My 1962 261 was green, I used the paint on a generator mounting bracket bolt that had probably never seen the light of day. Took it to a paint supply place and they used a spectrograph to obtain a formula. They used this to mix up a quart of high temp. machine enamel. Putting that old bolt head up to the now newly painted engine my old eyes could not see a difference.
My thinking is the engine colours were set due to passenger or commercial, size of truck, what displacement and possibly what plant built it. Grey, yellow, green or orange.
Post a photo, I bet it will look great! Howie
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine
4 1966 Plymouth VIP 5.7 GenIII Hemi
5 1966 Imperial Crown Coupe 440 engine
Re: '57 265 Chartreuse [Re: AtomicYJ] #1160996
Mon Apr 18 2016 01:33 AM
tclederman  Offline
Boltergeist
Jarvisburg, NC
Here is one "expert's" opinion.
http://www.1954advance-design.com/Web%20images/PPIP/PPIP-1912-1966-EngineColors.html
Note different 265 engine colors between years, and between car and truck 265s in some years.
Choose a color and go with it, and enjoy what suits your logic/taste/evidence.
Tim
Moderated by  53moneypit, Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
