The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (5WINDOWJOHN, Fox, festerhairball, Eureka Jim, Mike B, ccanepa50), 250 guests, and 3 robots.
Forums50
Topics121,426
Posts973,547
Members43,932
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Sleeve Seal on Torque Tube
#1160808 Sun Apr 17 2016 01:53 AM
After putting together the torque tube on my 38, I began to ponder how the seal is accomplished at the rear of the sleeve where the collar is. As it is tightened, the seal is compressed in width and the smaller diameter decreases to seal around the driveshaft tube. Now at the same tome the outer portion of the seal expands against the threaded collar. This would seal the collar but not the threads so where is the complete seal attained?
1951 1 Ton Completed
Re: Sleeve Seal on Torque Tube
truckernix #1160834 Sun Apr 17 2016 03:58 AM
I think what you are talking about is the Torque Tube Retainer
Sometimes for whatever reason one o-ring washer goes missing.
Or the two o-ring washers get stacked together inside the retainer cap.
My o-ring washer was missing.
You need one o-ring washer on each side of the rubber/cork seal/packing for it to seal correctly.
ilustration 1 Grp no. 5.576 washers Note: powerglide has same set-up shown, 37-54 all same size. Parts Catalog part no. 595013
illustration 2 Chevrolet's 1938 Shop Manual
Where to find
truckernix #1160847 Sun Apr 17 2016 05:05 AM
According to this 1954 Chevrolet Truck Shop Manual Picture (Remember all 1937-54 retainers caps are same size)
Figure 77, - Slip joint Packing (lower RH corner of page)
The threads are not cut all the way to the back of the retainer cap.
There looks to be a flat spot for the outside of the seal to lay onto.
truckernix #1160916 Sun Apr 17 2016 07:16 PM
I guess my question is, what stops the fluid from going between the housing and the steel washer and leaking out the threads. I think the steel washer is acting as part of the seal
truckernix #1160926 Sun Apr 17 2016 07:51 PM
ace skiver
There is a round rubber (maybe cork in some gasket sets) seal between the steel washers (47-54).
jorb posted a link to an illustration, above - the two metal "washers" and rubber/cork seal were used on 1/2 ton trucks' torque tubes.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
truckernix #1160936 Sun Apr 17 2016 08:32 PM
"I think the steel washer is acting as part of the seal"
When the retainer cap is tightened.
The two steel washers are squishing the rubber seal, making the seal bulge on the inside & outside.
Which makes a seal on the torque tube housing and the inside of the retainer cap.
But you are correct the inner washer in the retainer cap is also doing the sealing.
But the threads themselves are doing the sealing too.
Keep in mind we are not dealing with water and nothing is under any pressure, we are dealing with 90 weight gear lube.
Thick stuff.
truckernix #1161175 Tue Apr 19 2016 12:02 AM
ODSS Lawman
Also remember these truck leaked. Spots on the driveway are like territory marks.
SWEET
Sergeant At Arms
Old Dominion Stovebolt Society
BUNS?!?!?! Where we're going, we don't need no buns.....
1950 GMC 450 (25% owner)
1951 Chevy 1/2-Ton
The GreenMachine
In the Stovebolt Gallery [stovebolt.com]
Moderated by  SWEET
