Fixing the old truck
BUSY BOLTERS
Are you one?
Not a hanging chad... The Shop Area
Searching the Site
12 members (66flea, 68ironhead, baldeagle, Hotrod Lincoln, Danielbolt, 1 invisible), 111 guests, and 3 robots.
The Zone
Forums65
Topics123,444
Posts999,541
Members47,279
Most Online1,229
Jan 21st, 2020
Page 2 of 2 1 2
Since I just struggled with one side, I'll wait for some tips on the other side
I used plenty of soap and water (and some grease)
I did have to open up the channel in several places
just-a-hacker
'49 3100 before '99
Does anyone else agree that windlace was created by the devil? I think I've used up more hours trying to push this stuff in those grooves than anything else I've done on this truck. There must be an easier way!!!
1942 BK 1/2 Ton Pickup
1954 3800 1 Ton Pickup
There is. Buy an early '49 or earlier truck. They screw on.
hacker, I took a day break from the windlace and started on the passenger today. I sprayed the channel with liquid wrench spray lube and I found that the winblace slid much easier than when I used soap. Then the parts that didn't catch I just pushed in with a screw driver. Hope this may help you.
I have taken a few weeks break from the windlace after I got one side in,I also saw somewhere a note about putting headliner in first...good excuse to not install driver's side yet.
most of my windlace doesn't come near door
just-a-hacker
'49 3100 before '99
I used "personal lubricant" from the drug store. Cleans up with water and the wind lace popped right into the channel with a little persuasion from a plastic automotive trim stick. Hope this helps.
Tim
1970 VW Beetle
Tim's method is the correct answer: use a non-oil-based and non-silicone-containing lubricant AND widening all the "pinch" locations in the channels/tracks.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Tim,
Why do I think Woody probably would have made a special tool for this job .
just-a-hacker
'49 3100 before '99
Page 2 of 2 1 2
Moderated by  ndkid275, Phak1
