The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 members (CrowbarBob), 219 guests, and 3 robots.
Forums50
Topics120,033
Posts961,341
Members43,542
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Convert 235 To Electronic Ignition
#1159214 Fri Apr 08 2016 07:06 PM
U
UnklRod Offline OP
Hi all,
I am looking to convert my points distributor system to electronic ignition.
What product/brand is best?
Jon
1957 Chevy 1/2-Ton Truck
More pix
The coldest winter I ever saw was a summer I spent in San Francisco M. Twain
If at first you don't succeed...skydiving is not for you!
If you don't like my carbon foot print, stick it up your Prius!!
Re: Convert 235 To Electronic Ignition
UnklRod #1159217 Fri Apr 08 2016 07:12 PM
Big Bolt Forum Moderator
you can buy an HEI setup on Ebay with new wires for about 175$. My dad bought one for his 235 he has in his 40 chev car.
Mike
1955 Chevy 6400 ex-flatbed (no bed now!)
UnklRod #1159223 Fri Apr 08 2016 07:29 PM
U
UnklRod Offline OP
Ok thank you!
More pix
UnklRod #1159224 Fri Apr 08 2016 07:31 PM
U
UnklRod Offline OP
I still want to keep the "stock look."
More pix
UnklRod #1159348 Sat Apr 09 2016 12:13 PM
petronics or check out Deve's sight.
Tommy
59 apache 1/2t
261 short stepside
UnklRod #1159357 Sat Apr 09 2016 01:44 PM
Some have had some bad results using Pertronix electronic ignition, but I have not. I've installed the Pertronix unit on several older vehicles and not had any issues.
You can carry a spare set of points and condenser in the glove box just in case at some point it does give trouble. At least you could get home.
But so far i haven't had any issues with the Pertronix units.
They fit right inside your distributor keeping the original look.
UnklRod #1159389 Sat Apr 09 2016 04:45 PM
Moderator, Passing Lane
I had a mallory on my 235, worked well, sort of expensive though
Redryder
My Hotrod
I am fighting cancer and I am winning the fight
Pain is part of life; misery is an option.
UnklRod #1159439 Sat Apr 09 2016 09:21 PM
+1 for Pertronix.
My TRUCKS website
UnklRod #1159453 Sat Apr 09 2016 11:06 PM
...pertronix...close to stock look...
Deve has a good set up also
Not sure what's involved with his modification
UnklRod #1159499 Sun Apr 10 2016 03:23 AM
ace skiver
I use standard points or Pertronix on my 6v engines.
No problems with the Pertronix, but run a ground wire from a distributor-cap clip/clamp screw to the head.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Page 1 of 2 1 2
Moderated by  Rusty Rod
