BUSY BOLTERS
Are you one?
The Shop Area
8 members (Hotrod Lincoln, Gdads51, baldeagle, azcornman, JW51, frogfarmer, 1 invisible),
90
robots. |
Key:
Admin,
Mod
Forums65
Topics123,444
Posts999,549
Members47,279
Most Online1,229 Jan 21st, 2020
That sounds good. It will be a thick but self-leveling grease.
Fill it to the plug and then wait a while for the grease to level out. Then, top it up into the plug hole.
I wonder if "knuckle pudding " would work? Over at the Willy groups the guys mix 90 weight oil with grease half and half to put in the universal balls on the front 4wd axles. Say it stays in better, doesn't leak past the seals on the ball.
I wonder if "knuckle pudding " would work? Over at the Willy groups the guys mix 90 weight oil with grease half and half to put in the universal balls on the front 4wd axles. Say it stays in better, doesn't leak past the seals on the ball. Yep, that should work fine. That is what I did, but I used 120 weight gear oil and bearing grease. Mixed to self leveling consistency that I felt would still allow adequate lubrication to the top bearing.
OP
What type of grease is it just general corn head grease
A corn head grease is the correct consistency. John Deere sells it by the tube. People have posted other sources.
Press "Reply"
Use the second icon from the left (above the edit "window" - the icon is a globe with two chain-links under the globe.
Put the URL in the first box and then press "OK" Put the words/description in the next box and press "OK"
You can then edit the words/description, if you want to do so.
40 Chevy 1/2 ton
Fill it to the plug and then wait a while for the grease to level out. Then, top it up into the plug hole. This pipe plug is the fill plug on the top of the steering box correct?
1942 BK 1/2 Ton Pickup 1954 3800 1 Ton Pickup
. . . . This pipe plug is the fill plug on the top of the steering box correct? 1942? Yes, it is a/the pipe plug. Fill to just below below the base of the hole. Drive/steer the truck. Re-check the level and fill to just below the pipe hole. http://chevy.oldcarmanualproject.com/shop/1942/42csm0011.htm
