BUSY BOLTERS
Are you one?
The Shop Area
16 members (GMCJammer51, 32vsnake, Donf, Gdads51, baldeagle, 68ironhead, 1 invisible),
128
robots. |
Key:
Admin,
Mod
Forums65
Topics123,445
Posts999,547
Members47,279
Most Online1,229 Jan 21st, 2020
OP
I had about half my truck's grease fittings work correctly when I was greasing them up. What's the best way to fix the fittings that aren't taking grease? Replace them? Clean them?
1942 BK 1/2 Ton Pickup 1954 3800 1 Ton Pickup
You can always screw out the zerk and clean it up. Chances are the old grease in the moving part has packed in so tight that it is time to see over the innerds. Karl
It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe
OP
“Grease Monkey” “Former herder of cats”
Zerks are cheap. Pick up a few next time your at the flaps and you will have them on hand for these situations.
Martin '62 Chevy C-10 Stepside Shortbed (Restomod in progress) '47 Chevy 3100 5 Window (long term project) ‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily” ‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one! Support those brave men/women who stand the "Thin Blue Line"! Hug a cop! USAF 1965-1969 Weather Observation Tech (I got paid to look at the clouds)
A little heat from a butane microtorch usually frees them up for me. You can buy one cheap at Harbor Freight.
Yep, just replace the clogged ones. No point in wasting a lot of labor time to clean up a part that costs less than a dollar! Jerry
While you are replacing the grease fittings, use a small screw driver to clean out the hole. If the last grease that was used was the old soap based grease, its hard as a rock by now.
OP
Thanks! Are all the grease fittings the same diameter size? I know they have some that are straight and others are at an elbow.
Big Bolt Forum Moderator
I believe they have different sizes but most are 1/4-28 threads (at least the box of them I have is! LOL)
They also come in pipe thread and metric, so, measure carefully.
Ed
