The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (ccanepa50, festerhairball, Eureka Jim, five-oh, DennisM, 2ManyTrucks), 249 guests, and 3 robots.
Forums50
Topics121,426
Posts973,542
Members43,932
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Valve setup for 216 TDC
#1158077 Sat Apr 02 2016 12:03 PM
I was putting my 1940 216 together on the stand and I wanted to set the valve clearance. Of course I didn't have the flywheel on so I used the position of the lifters to deduce the proper spot for TDC. I noticed that there is a hole in my balancer just inboard of the pulley and it was at the very bottom at the time. I am wondering if that hole is there for reference.
1951 1 Ton Completed
Re: Valve setup for 216 TDC
truckernix #1158097 Sat Apr 02 2016 04:08 PM
If that is in the face, that where material was removed to balance the balancer.
Here is one on eBay with two holes.
My Blog
truckernix #1158099 Sat Apr 02 2016 04:15 PM
I guess I am just lucky but now I have a handy reference. When I put the flywheel on, I found out I had it half way between the triangle and the ball.
truckernix #1158155 Sat Apr 02 2016 08:39 PM
If you can't see any timing marks, using tappet motion isn't as easy as it looks - both valve are closed for a long time in these engines.
To help: the cylinders run in pairs. When one of each pair is @ TDC on compression (with both valves fully closed), its partner is @ TDC on overlap and has its valves moving in opposite directions. Pairs are separated by 3 places in the firing order (1 5 3 6 2 4).
Pairs are 1 & 6, 5 & 2, 3 & 4
Moderated by  Woogeroo
