Remember
The old Bulletin Board?
click to enter
The old Bulletin Board has been removed from the server. And with recent "spring" cleaning, we are removing links back to it. The BB is still out in cyber space (to some extent) thanks to The Wayback Machine.
Oh Lord, I just gotta find it....
Forums59
Topics128,108
Posts1,037,361
Members45,936
Most Online1,229 Jan 21st, 2020
OP
Trying to remove the rear end filler plug to check and change gear oil (1950 3100) plug seems to have been in there a while tried a 3/4" open end wrench and adjustable Must just be stuck any tips tricks or suggestions ?
Thanks Sam
1953 3100
It's a pipe thread, try tightening it slightly then loosen. Also might find a square socket to get a good bite on the plug.
BC 1960 Chevy C10 driver 261 T5 3.73 dana 44 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022
Big Bolt Forum Moderator
if you can get a square socket on it as BC59 suggested, you might try an impact. A lot of times, the blows from an impact will knock things loose that don't want to come loose by brute force.
OP
Thanks guys finally got it! square socket long bar and hammer - I think it may have been it there since the truck left the factory.....
1953 3100
Don't think it's pipe thread, the ones I've run across are straight thread with a gasket.
On stuck ones a pair of Knipex Plier Wrench have worked great for me.
On stuck ones a pair of Knipex Plier Wrench have worked great for me. That's correct. It's straight thread with a gasket. '63 and later have pipe threads for the filler, though.
Bill Burmeister
