The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
17 members (bob53, 51 3804, carbking, Aub1953, archburycontrol, Bill Bishop), 84 guests, and 3 robots.
Forums47
Topics117,778
Posts942,384
Members43,039
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
1953 Chevy 3100 - Making a daily driver
#1150430 Tue Feb 16 2016 04:01 AM
gsharum Offline OP
I bought my 1953 3100 a few weeks ago knowing it needed a lot of work. It ran and drove but the brakes were shot and had to be replaced with new wheel cylinders. The carb was leaking all over the place and would only run with the choke pulled out. The carb is out getting rebuilt now. I have cleaned up the engine and replaced the manifold gaskets . I also got the heat riser freed up with a new spring installed. I'm replacing the engine mounts and transmission mount this week. Wow, that driver side mount was fun removing!
I also removed the rotten bed and will start prepping for a new one.
My next big goal is replacing the rotten floor pans and kick panels . I'm trying to find someone to do this for me. I'm removing all the rust I can with Evapo-rust but will either blast or wire wheel the frame. The more items I take apart to fix, the more problems I find. Now I know why a good, clean AD truck goes for $20k or more. Anyway, it will all happen with time and good help from this forum.
Re: 1953 Chevy 3100 - Making a daily driver
gsharum #1150433 Tue Feb 16 2016 04:18 AM
Boltergeist
Way to go. Looks like you are well on your way to having a nice driver. Thanks for sharing. Those pictures sure to bring back a lot of memories for me!
Pictures in my Photobucket
52 Chevy Panel
gsharum #1150590 Wed Feb 17 2016 04:06 AM
gsharum Offline OP
rebuilt the rear transmission mount this evening
gsharum #1151177 Sat Feb 20 2016 03:48 PM
gsharum Offline OP
Got my carb back and adjusted the valves and she purrs like a kitten. Went for my first drive and guess what, the clutch slips bad and second gear grinds unless I double clutch or shift slowly. I know I need a new clutch but any chance that could be my issue with 2nd grinding or do I need to go ahead and put in new syncos?
gsharum #1151491 Mon Feb 22 2016 01:10 PM
gsharum Offline OP
I pulled the clutch and transmission this weekend and found my clutch slipping problem. Some of the pressure plate springs seem to be broken. I will have the transmission rebuilt while it is out.
gsharum #1154336 Thu Mar 10 2016 03:16 AM
gsharum Offline OP
Since my last post - new clutch, pilot bushing, pressure plate have been installed with resurfaced flywheel. A new gas tank was installed along with a new fuel pump. I also replaced all the seals related to the torque tube. A new oil pan gasket was installed as well. Its the first time since I bought the truck I don't have an oil leak! Although, wiggling the fuel lines around when removing the old tank did cause a leaky fuel petcock and 7 inch rubber line connected. Those have been ordered.
I almost forgot, I got the windshield wipers all working again with new transmission arm bushings and a good cleaning relube of the vacuum motor. Almost time to start some body work.
gsharum #1156886 Sat Mar 26 2016 04:07 AM
gsharum Offline OP
The truck didn't have parking brake cables when I bought it. Those were installed tonight so I can leave it running without rolling away now. I've been fighting a fuel gauge problem that's driving me nuts. I bought a new sending unit and gauge and with the tank full to the top it only registers 1/2 to 3/4 tank. If I remove the sending unit and move the float by hand it almost goes to full. I guess I will bend the float shaft to compensate.
gsharum #1157058 Sun Mar 27 2016 04:43 AM
gsharum Offline OP
New exhaust front to back!
Next big project will be replacing rear main seal. I'm tired of the leak.
gsharum #1158315 Mon Apr 04 2016 01:47 AM
gsharum Offline OP
I've been taking lots of short trips trying to figure out all the "issues". Today I went on a 60 mile round trip and it ran great. I love this old, rusty, loud truck! I've yet to go anywhere without someone giving me a compliment or asking about it.
Trip to the country
This weekend the dash got a coat of Rustoleum Flat Chestnut.
Dash 1
Dash 2
Dash 3
gsharum #1158316 Mon Apr 04 2016 01:56 AM
Big Bolt Forum Moderator
welcome to the site! Great to see pics and hear about your progress! I love these old rigs as well!
Mike
1955 Chevy 6400 ex-flatbed (no bed now!)
Page 1 of 2 1 2
Moderated by  J Lucas
