The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
17 members (GasHog, 57 Apache Stock, ADH, Greg_H, EdPruss, Johnny N), 91 guests, and 3 robots.
Forums50
Topics119,604
Posts957,727
Members43,440
Most Online1,229
Jan 21st, 2020
Image Posting Policy
'47 transmission
#1150339 Mon Feb 15 2016 07:46 PM
I have a '47 Chevy with a 3 on the floor that jumps out of 3rd. The truck came with an extra 4 speed and bell housing for a torque tube. The assembly is too long for my rears tube. Is the 3 speed the same transmission as a pre war truck? What years? There is a '54 rear and tube assy on CL would this work with the spare? Are the 54 rears geared any higher? Thanks for considering possible solutions.
Re: '47 transmission
47fivewindow #1150364 Mon Feb 15 2016 10:50 PM
High gear on 3 or 4 speed is direct.
Take your 3 speed out and replace the bearings, they are simple, not expensive, learn something new.
Ed
47fivewindow #1150376 Mon Feb 15 2016 11:55 PM
Q.The truck came with an extra 4 speed and bell housing for a torque tube. The assembly is too long for my rears tube.
Q. What year is extra 4 speed?
What year is extra bell housing?
Q. Is the 3 speed the same transmission as a pre war truck? What years?
A. Do not know for sure.
Q.There is a '54 rear and tube assy on CL would this work with the spare?
A. Looking at the Master parts Catalog Shaft, Group number 5.441 (propeller shafts)
The torque tube propeller shafts are the "Type C"
It says, 1947 1/2 ton propeller shaft O.L. overall length is 65 7/16" used on both the 3 or 4 speed trannys.
It also says it uses 17 splines.
1948-54 1/2 ton (except Hydramatic trans.) propeller shaft O.L. overall length is 63 7/8" used on both the 3 or 4 speed trannys. 17 splines.
That tells me 1954 tube assy is to short for your truck, if using the original 1947 3 or 4 speed trannys.
Master parts Catalog Carrier Assembly group number 5.504 (torque tubes)
1947 1/2 ton is 62 1/2" used on 3 and 4 speed trannys.
1948-54 1/2 ton is 60 1/8" used on 3 and 4 speed trannys.
How to measure Torque Tube
Q. Are the 54 rears geared any higher?
A. 1954 1/2 ton ring & pinion gear ratio > 3.90:1
1947 1/2 ton ring & pinion gear ratio > 4.11:1
Solution; Rebuild 3 speed transmission.
Last edited by jorb; Tue Feb 16 2016 04:58 AM. Reason: correct 1954 propeller shaft spline from 16 to 17
jorb #1150410 Tue Feb 16 2016 02:26 AM
Thanks very much. Your info provides options. The only thing about the 47 tranny if it needs some parts that prove difficult to obtain I hate to have it apart and unable to move. The spline count seems to be the key to finding a replacement.
EdPruss #1150412 Tue Feb 16 2016 02:33 AM
That is what will probably happen. I'll let you know what I find.
47fivewindow #1150453 Tue Feb 16 2016 06:56 AM
Is yours an early or late 1947? Does it look like a 46 or a 48. 1947 was a mid year body change.
Here is my blog post on jumping out of high gear.
My Blog
Pre '68 Dave #1150458 Tue Feb 16 2016 12:56 PM
It is a late model 47, but it seems to have an early drive line. Many things changed in 48.
47fivewindow #1150492 Tue Feb 16 2016 05:22 PM
The transmission in a 47 is the same as 1940-46.
That is the only direct interchange.
Some internal parts from later transmissions are interchangeable.
My Blog
47fivewindow #1150504 Tue Feb 16 2016 07:29 PM
thanks Dave. I don't suppose there were a lot of domestic vehicles produced in those years.
47fivewindow #1150531 Tue Feb 16 2016 11:25 PM
Parts are readily available for that transmission.
My Blog
Moderated by  SWEET
