We are still asking:
What did you get done on your Bolt today ????
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures and No BOTS.
So ...
What did you get done on your Bolt today????
Oh Lord, I just gotta find it....
Forums60
Topics127,583
Posts1,032,706
Members45,812
Most Online1,229 Jan 21st, 2020
 '59 Apache 283 w/SM420 4speed on floor
OP
If I can find an SM318 with OD will it bolt right up to the 283? Are there any other easy auto OD options to consider for around $500? What other adjustments would be necessary to the driveline, etc.? Is there an auto on the floor shifter that looks like a standard stick or go with on the tree? Thanks for the info.
 Re: '59 Apache 283 w/SM420 4speed on floor
With OD the designation is SM319. It will bolt to your bellhousing in place of the SM420. I'm not sure if the driveshaft length would be right.
Deve, a member of this site, has designed a floor shifter to be used with an SM319.
