The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (5WINDOWJOHN, Fox, festerhairball, Eureka Jim, Mike B, ccanepa50), 250 guests, and 3 robots.
Forums50
Topics121,426
Posts973,547
Members43,932
Most Online1,229
Jan 21st, 2020
Image Posting Policy
216 Installation
#1145379 Mon Jan 18 2016 09:46 PM
So yesterday I pulled the 216 on my 38 to overhaul it. I used two headbolt locations to secure the lift and all worked as planned. Thinking ahead when I go to install it again, I will be using the same two headbolt locations. So my question is, should I torque all the headbolts and then remove two or should I just snug them all down and torque them after the motor is in place?
1951 1 Ton Completed
Re: 216 Installation
truckernix #1145381 Mon Jan 18 2016 09:53 PM
ace skiver
I use two bolts for the rocker-arm assembly posts (and a load-leveler on the lift).
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
truckernix #1145383 Mon Jan 18 2016 10:12 PM
I have just torqued the two head bolts on several installations with no issues.
truckernix #1145394 Mon Jan 18 2016 11:44 PM
Gas Pumper
After
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
truckernix #1145415 Tue Jan 19 2016 02:16 AM
I would also torque the after, and again after a good worm up.
My Blog
Moderated by  Woogeroo
