The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Think Spring
Start planning those get togethers!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 registered members (49shep, J Lucas, TPR57C), 224 guests, and 3 spiders.
Forums47
Topics113,748
Posts902,571
Members41,701
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 4 of 6 1 2 3 4 5 6
Re: How many in the Seattle area? [Re: 69Cuda] #1211937
Thu Apr 06 2017 09:23 PM
3800apachegomez  Offline
Washington
I live right next to lowes on pacific hwy. In kent/des moines. Just purchased a 59 apache. Trying toget it running. It cranks but wont turn on. My name is Gil
Re: How many in the Seattle area? [Re: 69Cuda] #1212687
Tue Apr 11 2017 09:15 PM
69Cuda  Offline OP
Big Bolt Forum Moderator
Seattle, Wa.
Hi Gil, I'll have to stop by and see you, I am only a couple miles away.
Mike
1955 Chevy 6400 ex-flatbed (no bed now!)
Re: How many in the Seattle area? [Re: 69Cuda] #1223659
Mon Jul 03 2017 04:39 AM
Cornbinder  Offline
Burien, WA; King County
New member here--I live in Burien and have a 1966 C-10. I'm going to the Stovebolt Reunion this September but my truck is still incomplete so I'll be driving my wife's KIA to the reunion. EO
Re: How many in the Seattle area? [Re: 69Cuda] #1223676
Mon Jul 03 2017 02:12 PM
69Cuda  Offline OP
Seattle, Wa.
welcome to the site! I'm just a stone's throw away from you! If you get stuck on something, feel free to give me a shout
Mike
Re: How many in the Seattle area? [Re: KBrown] #1234858
Sat Sep 16 2017 05:54 AM
Chuck P.  Offline
WA
how much did blasting cost you? where did you have it done?
'64 Ford F-100
'51 Chevy 6400
Re: How many in the Seattle area? [Re: 69Cuda] #1234859
Sat Sep 16 2017 05:58 AM
Chuck P.  Offline
WA
New member down in Graham with a '51 6400 with a dump bed.
Front wheels are off, brakes apart, hoping new cylinders from O'Riley's will get her stopping on demand again.
can't get either bleeder screw loose on hydrovac.
'64 Ford F-100
'51 Chevy 6400
Re: How many in the Seattle area? [Re: 69Cuda] #1235650
Wed Sep 20 2017 03:42 PM
69Cuda  Offline OP
Seattle, Wa.
welcome Chuck! Maybe a little heat on the bleeder screws? sometimes just heating them up and letting them cool will loosen them up.
Mike
Re: How many in the Seattle area? [Re: 69Cuda] #1236385
Mon Sep 25 2017 09:31 PM
Rsr  Offline
Seattle, wa
I'm a new member from Shoreline area. I've got a '62 C20 that has a 350 & TH350 under the hood. It runs good.
I'm replacing the heater fan motor. The only issue at this time is the window washer doesn't shut off, if the button is pushed it will run till the tank is empty! Looking for replacement switch mechanism.
Rod
Re: How many in the Seattle area? [Re: 69Cuda] #1236413
Tue Sep 26 2017 12:13 AM
69Cuda  Offline OP
Seattle, Wa.
welcome to the site! Poke around a bit and once you make I think 4 posts you are no longer moderated and can PM folks. You will also be able to post in the parts wanted forum (don't think it shows while you are moderated).
Have you checked Ebay?
http://www.ebay.com/itm/Original-60-61-62-63-Chevy-Truck-Windshield-Washer-Wiper-Switch-2-Speed-GMC-1963-/311957473021?hash=item48a21d46fd:g:SS0AAOSw6YtZSahZ&vxp=mtr
When we had our 59 Suburban, I think I ended up getting one out of a 64-66. I had to make the hole in the dash larger and buy some super fine nuts off Ebay but, it was brand new instead of all old contacts inside.
Mike
Re: How many in the Seattle area? [Re: 69Cuda] #1236462
Tue Sep 26 2017 04:58 AM
Rsr  Offline
Seattle, wa
I got the heater motor replaced. I had to modify the wheel, the raplacement motor shaft was smaller than the stock. The replacement came with a shim to fit the shaft. This allowed the wheel to spin on the shaft. I drilled and tapped the wheel and put in a set screw. It wo is great now!
Rod
Moderated by  69Cuda
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
