The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Thinking again ...
We are still asking:
What did you
get done on
your Bolt today
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt
this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures
and No BOTS.
So ...
What did you get done on your Bolt today????
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 members (coilover, KevinW, dunfire, 51Craig1Ton, 53 green 1- ton, 2 invisible), 72 guests, and 3 robots.
Forums60
Topics127,583
Posts1,032,707
Members45,812
Most Online1,229
Jan 21st, 2020
Image Posting Policy
'59 Apache oil bath set up
#1137996 Sat Dec 05 2015 11:41 PM
can someone send a pic of how the oil bath air cleaner is set up on a 283 engine. does it work as well as putting a new air cleaner on the rig? I perfer the original equipment. thanks.
Re: '59 Apache oil bath set up
JackAttack #1138063 Sun Dec 06 2015 05:57 AM
what means "set up"?
like any air cleaner, if it fits the carb, put it on and tighten the clamp .... depending on what you can find, looks like this on a 58 283 or like this on a 57 .... an oil bath works better than a dry filter in particularly dusty conditions
JackAttack #1138096 Sun Dec 06 2015 02:57 PM
Here is an older thread related to the subject. Might help some. Pictures of the from the 60 shop manual and the physical air cleaner that I have on a 62.
http://s1377.photobucket.com/user/douglashamilton1/slideshow/283
http://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1125144/Re:_Oil_Bath_Air_Cleaner.html#Post1125144
HB
1966 Chevrolet K-10
Flappy Fenders
In the Stovebolt Gallery [stovebolt.com]
More pictures on Photobucket [s160.photobucket.com]
1962 Chevrolet C10
1962 Suburban
JackAttack #1138299 Mon Dec 07 2015 06:08 PM
Oil bath is a great system. It does take a little extra to pull the air through it than a dry filter, but it works well.
JackAttack #1138319 Mon Dec 07 2015 08:12 PM
Works Well?
When volcanoes fill the air with ash they are about all that works... I'd call that great!
Give me ambiguity
or give me something else
JackAttack #1138335 Mon Dec 07 2015 11:08 PM
Oil bath air filters do in fact work well. Most real fine dirt is trapped in the oil(even the micro-fine stuff. The only issue might be airflow. Ever wonder why the filter is so big? Problem solved. Same tech. is used by K and N performance filters. When I raced in wet, or dusty conditions we used an oil soaked "sock" to wrap around the dry paper filters to protect the paper. Skip the paper and drive happy. The "mesh" element traps a lot of dirt because it is "wet" Air gets a free pass. Dirt gets stuck. Why did we go to replacement paper filters? No mess and no skill to replace. When does any one clean a filter these days? K and N uses a cotton fiber to replace the mesh and an oil spray to replace the "bath". They work well too.
Steve H
Moderated by  Woogeroo
