The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 members (47PUJim, GMJim, 1866yellowboy, Pre '68 Dave, 1 invisible), 259 guests, and 3 robots.
Forums60
Topics123,450
Posts996,251
Members44,670
Most Online1,229
Jan 21st, 2020
Image Posting Policy
12 volt battery
#1134264 Sat Nov 14 2015 05:40 AM
jer3545 Offline OP
does anyone know what kind ,brand name 12 volt battery will fit in the floor mount 49 chevy 1 ton 3800 ? there was one in there ,it went bad , got rid of it and placed a 12 volt batt.I had but its two long to go into the batt. compartment . Yes ,it was converted to 12 volt ,for sure. Thanks Jerry
Re: 12 volt battery
jer3545 #1134271 Sat Nov 14 2015 01:12 PM
It is common to relocate the rear of the battery box a few inches further back and make a longer bottom for it. That'll help fit most any battery you want. Limiting factor is then opening in floor. So make a hinged or removable bottom and put the battery in from the bottom.
Grigg
1951 GMC 250 in the Project Journals [stovebolt.com]
1948 Chevrolet 6400 [stovebolt.com] - Detroit Diesel 4-53T - Roadranger 10 speed overdrive - 4 wheel disc brakes
1952 Chevrolet 3800 pickup [stovebolt.com]
---All pictures [picasaweb.google.com]---
Re: 12 volt battery
jer3545 #1134352 Sun Nov 15 2015 01:20 AM
My 37 and 52 batteries are in the stock location and size. I took a measurement, went to a "battery place" and measure what they had till I found one with the dimensions I wanted and had all the reserve/amps and such that I determined suited my needs.
I ended up with good one from Advance for the panel but choose a diehard for the 37. Its one of the easiest job you'll do on your truck.
1937 Chevy Pickup [stovebolt.com]
1952 Chevy Panel [stovebolt.com]
52 Chevy Panel [photos.app.goo.gl]
Pictures in my Photobucket [s140.photobucket.com]
https://photos.websearch.com/share/...Nko1cUJCNFFMTVFEUnNRbjFhNTFPc1J4YWV4cmRB
Re: 12 volt battery
jer3545 #1134366 Sun Nov 15 2015 04:23 AM
jer3545 Offline OP
Big thanks to Grigg and Achipmonk for the advice. I will go the easy route first .Take my measurements to the store and see what they have in that size.
Re: 12 volt battery
jer3545 #1134368 Sun Nov 15 2015 04:31 AM
Yes, they'll have one.
I was not implying you need to modify the battery box, but it is pretry easy if you want to, if you want a larger battery.
Moderated by  Grigg
