Major event in Virginia
ODSS Bolters
return from
WINCHESTER
Virginia
September 21-23
Rolling in Winchester VA Read the
HOT WASH!
Searching the Site
18 members (2-Ton, 78buckshot, AS37, 1Ton_tommy, 2ManyTrucks, 2 invisible), 172 guests, and 3 robots.
The Zone
Forums65
Topics123,390
Posts998,842
Members47,294
Most Online1,229
Jan 21st, 2020
Page 4 of 4 1 2 3 4
oldbluetruck #1127348 Thu Oct 01 2015 07:49 PM
Dennis,
In case you have not seen the mind-bogglingly-simple technique for tuning timing & carburetor with a vacuum gauge, here is an abbreviated run-down.
1. Disconnect the rubber line from the vacuum wiper motor to the port/fitting/tube on the intake manifold (at the intake manifold).
2. Connect a rubber line/tube from the vacuum gauge to the vacuum fitting on the intake manifold.
3. Start the engine and warm it up.
4. Set the idle RPM to around 450-500 RPM (or, by ear, if do not have a tachometer).
5. Adjust the timing by rotating the distributor slowly in both directions, to obtain maximum vacuum. At max vacuum, tighten the bolt on the distributor.
6. Re-adjust the idle speed, if necessary.
7. Adjust the mixture screw on the carburetor to obtain maximum vacuum.
8. If you want to continue, repeat steps 4-7.
9. Disconnect the vacuum gauge hose at the manifold and quickly reconnect the vacuum hose to the wiper motor.
10. Go for a test ride.
Good luck.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
oldbluetruck #1127393 Thu Oct 01 2015 11:17 PM
Great post Tim!
I especially like step #8. A lot of people (me included) often forget to do that.
If your idle was on the high side after you reach maximum vacuum, the mechanical advance in the distributor could have begun to kick in, monkeying up the process. This could be the case for both mixture, and timing adjustments.
Carl
oldbluetruck #1131816 Thu Oct 29 2015 03:00 AM
Tim, is it me or is it hard to find all your good tech advice on your web site? For example, your tuning steps above. Maybe you just put it all here?
Allen
1974 Stingray Corvette
oldbluetruck #1131944 Thu Oct 29 2015 10:52 PM
Thanks to all. Good advice. I took the timing light back and used my vacuum gauge.
Thanks Tim. As always
Dennis
oldbluetruck #1241348 Mon Oct 30 2017 06:24 PM
Where is the mixture screw on a Rochester B carb?
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Page 4 of 4 1 2 3 4
