The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 members (Brad Allen, carbking, Bill Bishop, Mike Burns, Aaron, 1 invisible), 139 guests, and 3 robots.
Forums50
Topics118,989
Posts952,475
Members43,304
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 4 of 6 1 2 3 4 5 6
Re: Definitive Suspension list for Stovebolts
Scott Danforth #1083618 Wed Feb 04 2015 08:51 PM
do I understand that using a 73-87 chevy truck subframe bolted onto a 51 chevy truck 3100 original chassis and by using the cpp modular drop spindle will position the track width near the 53 original track width with no alignment problems?
thanks, phil
hopalong66 #1084018 Fri Feb 06 2015 06:15 PM
Hi Everyone
I hung a pair of 1990's 1/2 ton rear Chevy truck leaf springs on my 1952/53 1 ton Chevy truck I call "Howard Knapp" I bought the both rear springs with all the hangers still attached (local price was $200.00). Took me a week with the "Liquid Wrench" to get everything loosened up so I can hang them on the 1952/53 Chevy frame. 16 5/16" x 1" long hardened steel hex head screws and the rear springs were in place. I had to cut the 1985 Chevy Blazer spring perches and I bought a pair from "Speedway Motors" spring perches...I think I had to move the perches out about 1/2" on each side. 1985 Chevy Blazer rear shocks from Rock Auto. Had to fabricate some hangers for this stuff tho...
Hope this helps someone out.
MikeC
Howard Knapp
More pix on Photobucket
Scott Danforth #1118076 Sun Aug 09 2015 02:32 AM
I used a trailing arm rear suspension from jimenez bros in California, and a jaguar IFS in my 51. Still working on the drivetrain, so no review yet..
Jcrapola
When you are dumb, you have got to be tough!
Scott Danforth #1130116 Mon Oct 19 2015 12:42 AM
So what does everyone thing about other ifs installations, from a nova,camero,firebird ect.. I know everyone makes kits and you can buy them and they come with instructions, what about the gray area of figure it out by yourself kinda wrench turning. Just wondering because I am thinking about taking a project of my own 71 nova sub frame on to a 1951 3600 chevy.
Scott Danforth #1132729 Tue Nov 03 2015 06:39 PM
Moderator - The Electrical Bay and Rocky Mountain Bolters
I installed a Heidts weld in kit on my 39 chevy pickup.
I worked perfectly, even though the frame was bent a bit behind the right front spring, which caused an 1/8" difference in length from side to side. I split the difference. It rolled straight down the freeway.
Another quality post.
Real Trucks Rattle
Scott Danforth #1133189 Fri Nov 06 2015 04:20 PM
BnJ Offline
hey Guys,
Im just adding my 2 cents here: I put a 1988 C1500 rear
end under my 50 AD. Used the stock springs,hangers,and shock mounts and moved the spring saddles and shock mounts on the rear end. The stock 88 Chevy PU wheels with 255/70R 15 tires fit perfectly and line up just inside the running boards. The set up looks great especially since I didn't want to use deep dish positive offset wheels. So your rear end list doesn't need to stop at 1987,
fyi, Bill
Scott Danforth #1136697 Sat Nov 28 2015 09:24 AM
Does anyone have good info on where to locate the mounts for rear shocks on a 1953 1-ton GMC? Mine has nothing, so I ordered some generic weld-on brackets to mount modern shocks. But I don't know where best to put them.
1953 GMC 1-Ton Pickup with 350 and 700R4
Scott Danforth #1150483 Tue Feb 16 2016 04:38 PM
BnJ Offline
I used the set up from Chassis Engineering purchased through JPL speed. Bolt in easy to install, 11in Chevy format brakes, and free shipping....about $2300 with sway bar. I did cut a coil off the springs to soften them up. Used the "steering column saver" original column with 2 U joints and a 3/4in DD shaft. works great.
Have fun,
Scott Danforth #1150497 Tue Feb 16 2016 06:14 PM
I always thought if you shorten a coil spring you make it stiffer. I've been wrong before.
Brian
My 1955 Truck
My other 1955 Chevy
Scott Danforth #1153908 Mon Mar 07 2016 05:16 PM
BnJ Offline
Hey Guys, one thing to consider when going to a MII front end is the original AD frame design has no welds. They were all riveted together which is part of the AD design. Most of the MII front end "systems" are weld in and require the frame to be boxed in to maintain the original frame strength. To box in part of a frame is a tedious job to make look clean and neat. With this concept in mind, I used a MII system from Chassis Engineering that bolts in the cross member and spring hangers and necessary hard ware and no frame boxing is necessary.
just an fyi
Moderated by  KCMongo
