The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
18 members (clrh2ofrank, drdoug, baldeagle, 81tta, 2ManyTrucks, DougR), 241 guests, and 3 robots.
Forums50
Topics120,082
Posts961,743
Members43,554
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 3 1 2 3
rear axle swap
#1128284 Wed Oct 07 2015 01:13 AM
koolkar Offline OP
I've been looking but can't find a topic regarding rear axle swaps for a 1 1/2 ton. I have the 2 speed vacuum shift that is stock. I also have a 95 chevy 3500 h.d. for a donor. I want to swap the entire axle assembly and use the cross member from the 3500 so I can have rear shocks. I realize I will probably will have to rework the drive shaft but am wondering about spring perch relocation. my back is hurt right now so I can't go measure.anybody know if I will have to relocate the perches? u bolts using the stock springs?
Re: rear axle swap
koolkar #1128305 Wed Oct 07 2015 03:03 AM
I used the same axle from a P30 chassis and had to move the spring pads. Think the 3500hd has same frame width, still be nice to measure and check.
Had you asked this morning I could have measured a 3500hd at lunch... A friend of mine runs a junk yard and had one on the roll back as he stopped for lunch too. Just a cab and chassis, would have been real easy to measure.
1951 GMC 250 in the Project Journals [stovebolt.com]
1948 Chevrolet 6400 [stovebolt.com] - Detroit Diesel 4-53T - Roadranger 10 speed overdrive - 4 wheel disc brakes
1952 Chevrolet 3800 pickup [stovebolt.com]
---All pictures [picasaweb.google.com]---
Re: rear axle swap
koolkar #1128310 Wed Oct 07 2015 03:57 AM
I have a 2015 3500HD. The frame rails are 34". Moving spring seats is no big deal. Just cut the old ones off and weld new ones on, It doesn't have to be a particularly good weld because the U-bolts are what does the holding. What are you going to do about wheels? A driveshaft shop can make any kind of driveshaft you need and they are not very expensive.
Re: rear axle swap
koolkar #1128326 Wed Oct 07 2015 05:45 AM
koolkar Offline OP
using the 19.5 tires and wheels. the c.o.e. already had the wheels changed when I bought it. guess i'll start calling spring shops tomorrow to try and find spring perches
Re: rear axle swap
koolkar #1128328 Wed Oct 07 2015 06:18 AM
koolkar Offline OP
Re: rear axle swap
koolkar #1128339 Wed Oct 07 2015 12:22 PM
I assumed the 3500HD is one with an I-beam axle and 10 lug wheels, back when HD meant something. Seems everything now days is HD or Super Duty...
You may use the spring pads off the original axle as it, the Dana 80, and 70HD all have 4" axle tubes.
Re: rear axle swap
Grigg #1128357 Wed Oct 07 2015 03:09 PM
koolkar Offline OP
it is a 3500 h.d. with 10 lug 19.5 wheels. thanks for your help.
Re: rear axle swap
koolkar #1128377 Wed Oct 07 2015 05:39 PM
Although today's 3500HD is built with a pickup cab, they have more capacity than the old 3500 with 20". The wheels are 17" duals with 8 hole metric.
https://plus.google.com/11263693037...5156051106&oid=112636930370126476644
Thee trailer has 17.5 singles that carry as much as 16" dual with a lot less rolling resistance. Although I have a CDL, the single tires keep me under the radar with DOT hassle. Most troopers haven't been taught that 17.5 singles carry more than16" duals.
The term HD with a GMC is not just a macho term. Take a look at a 2015 3500HD GMC. It amazes me how they are build, and I have been around trucks for over 50 years.
Re: rear axle swap
koolkar #1128379 Wed Oct 07 2015 05:46 PM
koolkar Offline OP
ummmm...... about what, 16000 pounds of Emeryville there?
Re: rear axle swap
koolkar #1128396 Wed Oct 07 2015 07:30 PM
Yes, they're capable trucks.
With out side tracking this thread too much.. My point was if ALL the standard pickup trucks are now called "HD" and "Super Duty" then what do you call something that really is heavy duty in comparison to them? "Extra Super Duty", or "Extremely More So Heavy Duty"... I find the whole thing ironic and comical.
Grigg
Page 1 of 3 1 2 3
Moderated by  69Cuda, Grigg
