The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
What's going on?
What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 members (1 invisible), 94 guests, and 3 robots.
Forums59
Topics128,612
Posts1,041,915
Members46,061
Most Online1,229
Jan 21st, 2020
Page 1 of 2 1 2
#1124532 Wed Sep 16 2015 10:09 PM
Dogface Offline OP
Don't really know if that's what it's called but the one I put in mine keep tearing and leak. They seem to all be made of cork which is preformed into a bell shape and my wrench said he doesn't know if anyone makes these out of better material. Hopefully someone here will know.
I did a search and found some info but it sounded like guys were talking about a different part and pics posted or linked to didn't show any bell shaped preformed gasket.
I have to have mine replaced every several months. Can't afford to convert to open drive line.
Thanks for any/all replies
Mark
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
Is this the gasket?
...pic...
Maybe your mechanic didn't shim it properly?
Dogface Offline OP
I havn't actually seen it...described to me by my mechanic, but I know he said it's preformed and made of Cork. Looks to me like a big O ring would do the job ?
Mark
1949 Chevy 1/2-Ton
Lucielle
The cork seal that Gus has posted, is a square cross section
when new. After it's been compressed and in service it takes
on sort of a wedge shaped cross section, maybe that's what
he's talking about.
The flange gaskets, which also act as stacking shims, are
available from any one of the antique truck vendors or any
auto parts should be able to get them also.
dg
Dogface Offline OP
I wish I personally knew more but I don't. All I can say is that he said it's preformed into a bell shape. He's not a newbie at working on these old trucks so I don't think he's missing the boat. He just said they are preformed cork and that the cork gets worn by the movement of the truck's suspension flexing etc. I can understand that being the case and the soft cork getting torn or worn thru.
I did search thru some of my catalogs online and didn't find any thing that I thought looked like what he said. I know a guy in Oregon who resto's these...likely he has a source. Dr. J wink who is part owner of The Filling Station
Mark
1949 Chevy 1/2-Ton
Lucielle
Here are the gaskets and shims that come in the kit
...pic...
The metal rings in that pic do Not come in the kit
If your ball gasket is getting eaten up from driving then its probably to tight, instructions are in the shop manual for proper play.
Dogface Offline OP
OK...got it. It's the cork one. I'll pass this along to him for future reference. Still, I wonder why no one makes that cork gasket out of a more substantial material...
Mark
1949 Chevy 1/2-Ton
Lucielle
Simply because the cork seal has worked for around 80 years
now, when properly installed.
Denny Graham
Sandwich, IL
Dogface Offline OP
I get it. I had thought that everyone had problems like I do.
Mark
1949 Chevy 1/2-Ton
Lucielle
I put some gooey Lucas oil on mine to allow it to slide into position. I think that helped a lot. I was thinking that dry it might stick and partially rip.
Page 1 of 2 1 2
Moderated by  SWEET
