Oh Lord, I just gotta find it....
Forums59
Topics128,080
Posts1,037,102
Members45,928
Most Online1,229 Jan 21st, 2020
OP
Don't really know if that's what it's called but the one I put in mine keep tearing and leak. They seem to all be made of cork which is preformed into a bell shape and my wrench said he doesn't know if anyone makes these out of better material. Hopefully someone here will know.
I did a search and found some info but it sounded like guys were talking about a different part and pics posted or linked to didn't show any bell shaped preformed gasket.
I have to have mine replaced every several months. Can't afford to convert to open drive line.
Thanks for any/all replies
Mark
Is this the gasket? ...pic... Maybe your mechanic didn't shim it properly?
OP
I havn't actually seen it...described to me by my mechanic, but I know he said it's preformed and made of Cork. Looks to me like a big O ring would do the job ?
The cork seal that Gus has posted, is a square cross section when new. After it's been compressed and in service it takes on sort of a wedge shaped cross section, maybe that's what he's talking about. The flange gaskets, which also act as stacking shims, are available from any one of the antique truck vendors or any auto parts should be able to get them also.
dg
OP
I wish I personally knew more but I don't. All I can say is that he said it's preformed into a bell shape. He's not a newbie at working on these old trucks so I don't think he's missing the boat. He just said they are preformed cork and that the cork gets worn by the movement of the truck's suspension flexing etc. I can understand that being the case and the soft cork getting torn or worn thru. I did search thru some of my catalogs online and didn't find any thing that I thought looked like what he said. I know a guy in Oregon who resto's these...likely he has a source. Dr. J  who is part owner of The Filling Station
Here are the gaskets and shims that come in the kit ...pic... The metal rings in that pic do Not come in the kit If your ball gasket is getting eaten up from driving then its probably to tight, instructions are in the shop manual for proper play.
OP
OK...got it. It's the cork one. I'll pass this along to him for future reference. Still, I wonder why no one makes that cork gasket out of a more substantial material...
Simply because the cork seal has worked for around 80 years now, when properly installed. Denny Graham Sandwich, IL
OP
I get it. I had thought that everyone had problems like I do.
I put some gooey Lucas oil on mine to allow it to slide into position. I think that helped a lot. I was thinking that dry it might stick and partially rip.
