The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 members (clarsen3100, Hotrod Lincoln, den-den, DennisM, 48bigtrucks, 1 invisible), 109 guests, and 3 robots.
Forums50
Topics119,434
Posts956,247
Members43,401
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1951 Speedo and Tach
#1122706 Sat Sep 05 2015 03:50 PM
I thought that I would add some pics of the new project that I am working on. I originally found this on the H.A.M.B. (Jalopy journal) and thought that I would give it a shot. The intent for my truck is to update the wiring to 12v and update the engine to a newer straight 6 (Chevy 292 cu from a 65 3/4 ton) so why not add a tach at the same time. I will be adding new SW guages with black face and white numbers to replace the original guages, so I thought the speedo and tach should match as well. I went to a local sign shop and had them replicate the speedo face in black and create a tach face for me using the original font. They created decals which go over top of the original speedo face. I will add more pics as the project progress.
http://s1075.photobucket.com/user/1...0Tach/image.jpg1.jpg.html?sort=3&o=0[/url]
1966 Chevrolet Caprice 2 Door Hardtop (396 Big Block)
1951 GMC 9434 5 Window (waiting on a 292 transplant)
Re: 1951 Speedo and Tach
5 Window 9434 #1122740 Sat Sep 05 2015 10:56 PM
Nice! Those gauges will look great.
5 Window 9434 #1124055 Mon Sep 14 2015 01:07 AM
Jim,
Thanks. I have added a few more pics. Same link as above. I still have to repaint the centres as I had a small screwdriver slip. Next step is to add the needles, glass and bezels.
Dave
5 Window 9434 #1124072 Mon Sep 14 2015 02:19 AM
It appears that your speedometer shaft is broken
But hard to tell from the pics
You may want to check it out.
5 Window 9434 #1124075 Mon Sep 14 2015 02:42 AM
Hard to tell, but the shaft is good. I wasn't so lucky with the first speedo that I took apart, snapped the shaft off at the base of the needle.
Dave
5 Window 9434 #1133866 Wed Nov 11 2015 03:22 AM
I added 2 new photos of the speedo and tach, with the needles installed and also a photo with the glass and bezel installed on the tach. Still waiting for the new bezel and gasket to show up for the speedo. For the speedo I have installed a odometer for a 53 Vette which has the black with white numbers, I also have a reproduction odometer with the white with black numbers for the AD trucks, just not sure which way to go for the odometer. For those that are restoring a speedo, Jim Carter sells the reproduction odometer. Once I have the bezel and glass installed, I will post more pics.
Dave
Moderated by  ndkid275
