The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (3hansens, 55shaker, 68ironhead, ApacheFiend, 3 invisible), 103 guests, and 5 robots.
Forums60
Topics126,065
Posts1,018,869
Members45,419
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: 4TH GEAR CLUTCH SLIPPING
WILLIAM RATHKE #1119717 Tue Aug 18 2015 06:20 PM
I should note that if I let the clutch out and push back in between 3rd and 4th gears it goes smoothly.
Tripleeeng #1119750 Tue Aug 18 2015 09:59 PM
Originally Posted by Tripleeeng
Mine has started grinding going into 4th gear. Is this the same issue or similar? should I be looking at something different all together? 1950 3100, 4 spd trans.
This is not the same thing. You have a bad syncronisor on 4 th gear in the trans. In your next post you mentioned letting the clutch out in between the shift. This is called double clutching. It was nessesary back before they had syncros in them.
1972 Chevy c10 Cheyenne Super
WILLIAM RATHKE #1119883 Wed Aug 19 2015 05:10 PM
Thanks. I was afraid of that. And I always called it double clutching but someone corrected me once and said there was more to double clutching than that. Can't recall what he tried to explain to me but just in case, I avoid using that term when asking for advice from guys that know more than me. I want to be as accurate as I can.
Page 2 of 2 1 2
Moderated by  SWEET
